Monty`s Mk1 Camper
Re: Monty`s Mk1 Camper
Postby montym100 » Wed Jun 15, 2011 9:08 pm
So the 1st few jobs to do,
Oil & filter change
Fuel filter?
Spark plugs
air filter
adjust valves/tappets
Gearbox oil change
Check rear diff as i think there`s a leak
After that i want to sound proof and carpet the front cab and sound proof the bulkhead in the engine bay but what materials do i need to use?
montym100
Postby Luke » Wed Jun 15, 2011 9:19 pm
while your doing the service get some grease into the kingpins :idea: :D
Postby montym100 » Wed Jun 15, 2011 9:22 pm
Luke wrote:while your doing the service get some grease into the kingpins :idea: :D
Yes i forgot to add that, she did get an advisory on the MOT for a bit of play in the pivot pin, i take it that the King pin :? So i`ll need to get myself a grease gun
montym100
Postby montym100 » Sun Jun 19, 2011 2:16 pm
any advice on sound proofing and what type of carpet to use in the front cab?
Even though the steering is heavy and quite a bit of play (must need adjustment) a little noisy i love just pottering about in her :mrgreen:
montym100
Postby transitandy » Sun Jun 19, 2011 3:43 pm
keep up the good work m8 :)
Postby montym100 » Mon Jul 04, 2011 6:55 pm
New Diaphragm for the Carb is now fitted and no leaks :D
viewtopic.php?f=3&t=91343
Were hoping to take it to Robin Hoods Bay for a couple of days later this month just to give her a try out. But think i may do a bit of rewire as there`s no Consumer unit and fit a few lights inside too.
I`m not fully clued up on what i need but i`m learning, i was thinking of buying one of these
http://www.ebay.co.uk/itm/GARAGE-CONSUM ... 3368768531 what MCB`s do i need? this one comes with 16amp and 6amp, will the 6amps be ok for fitting lights?
Thinking of fitting 4 sockets, will that be ok with this RCD unit?
Also going to buy some sound proofing and carpet from http://www.woolies-trim.co.uk/ for the front cab to make it a bit more quite.
Also need to check all fluids ie Rear diff, gearbox etc
What type of grease gun do i ned for the old girls nipples?
montym100
Postby montym100 » Tue Jul 12, 2011 7:59 pm
Hoping to go away for a few days next week so i`ve fitted a new sink but waiting for new tap and drainage fitting, bought a stove with a grill of ebay. Started cleaning inside and washed the seat cushions and pillow cases and had the hoover out :D
The campsite is booked up for Hookups :roll: so i`ve ordered a 100amp split charger and going to replace the battery with 125amp leisure type. Just need to rewire the radio, 12v light and the triple cig light thing so they run from the 2nd battery. The water pump for the sink and the tiny fridge is already wired.
Ordered carpet and sound proofing for the front cab from Woolies, that should be here soon. Alot to do.
montym100
Postby montym100 » Mon Jul 18, 2011 4:37 pm
Just an update,
Ripped old carpet out of the front cab, found a little rust
Sanded
Painted
Sound deadening going down
Sound deaning on the bulkhead and split charger installed
montym100
Postby Neil » Mon Jul 18, 2011 5:36 pm
don t mind me but should that felt not be on the inside of the bulkhead :shock: :?:
Neil v6
Neil
Postby davev6newman » Mon Jul 18, 2011 6:36 pm
It would have been easier to do it on the inside and then covered it in carpet i think. But nether the less good job done.
Could also stick some to the underside of bonnet, if your not too worried about the look of it.
davev6newman
Postby Neil » Mon Jul 18, 2011 6:44 pm
its fireproof then :?:
Neil v6
Neil
Postby montym100 » Mon Jul 18, 2011 7:02 pm
It`s not finished yet guys lol, the felt goes all the way up the bulk head on the inside just that i had to paint the floor 1st and then i ran out of spray adhesive for the bulk head section. The carpet is already cut so hopefully tomorrow the front cab should be finished, more photo`s to come
The Felt in the engine bay is Fire retardant to BS FMVSS302 bought from http://www.woolies-trim.co.uk/c-126-felt.aspx :wink:
montym100
Postby madmark » Mon Jul 18, 2011 7:12 pm
looks good and will keep the noise down :wink:
Postby Neil » Mon Jul 18, 2011 9:06 pm
fire retardent to what exactly :?: not fireproof full stop :!:
Neil v6
Neil
Postby Luke » Mon Jul 18, 2011 9:10 pm
looking good 8) 8)
mk5's have the sound deadning on the inside of the engine bay neil :D
