few pics of the new van so far
Postby chopper123 » Tue Jun 21, 2011 4:57 pm
just a few pictures of how im getting on with the camper so far
still got all the inside to do yet
and start the body work but it isnt to bad
next job will be insulation --sky light --and boarding
chopper123
Re: few pics of the new van so far
Postby plonka69 » Tue Jun 21, 2011 7:14 pm
did you fit the sliding door window yourself... looking at fitting same to my mk6 as dont like the mk6 all glass look
plonka69
Postby chopper123 » Tue Jun 21, 2011 7:35 pm
yes mate fitted my self easy job on a mk5 as you have a patern to follow on the inside with the jigsaw
i just took the base off of the jig saw and cut from the inside simple
but if you want to fit a mk5 side window into a mk6
i would say your best finding a mk5 and making a card board template of the cut out
then transfering it to your mk6 and see if all will be well
as mk6 uasualy have the bonded type like you say
chopper123
Postby plonka69 » Wed Jun 22, 2011 10:31 pm
will give it a look into..cheers for the advice... anythings possible with the right advice
plonka69
Postby transitandy » Wed Jun 22, 2011 10:40 pm
looks a clean one m8 :) and always love the camper conversions :) 8)
Postby ake » Thu Jun 23, 2011 7:50 pm
To fit a Mk5 window to a MK6 you actually need to cut the hole from the MK5 door and weld it into the Mk6 door, beacause the MK5 window is recesssed in. If you just cut a hole and stick the window in it will sit proud of the MK6 door and you could grab onto it and pull it from the door
cron
