Lowered my connect.
Lowered my connect.
Postby van mann » Sun Aug 07, 2011 9:08 pm
Having had all the bits for a few weeks now i dicided to start the conversion.
Decided to start with the front.
Focus rs springs,cups,bearings and top mounts with standard connect shocks
Modified and standard shock sise by side.
Took the beam off ,made and welded new brackets into place,exactley 180 degrees from the original.
As the rear is a simple axle flip the common problem is that the rear sits too low when this is done,so dicided to mod the rear spring mounts allowing the rear to be adjusted.Made these 4 bracktes,bolted them together and shaped them all the same
Made a simple jig so they are in the same place when welded to the spring mount
All welded and painted.
Then fitted,as the bracket was 8mm wider i needed a longer bolt.
van mann
Re: Lwered my connect.
Postby L200Lee » Sun Aug 07, 2011 9:15 pm
More pics!! :D
I like to think This forum was a boring place until I turned up!
L200Lee
Postby jonny s » Sun Aug 07, 2011 9:16 pm
^^^ as above :D
jonny s
Re: Lowered my connect.
Postby L200Lee » Sun Aug 07, 2011 10:18 pm
Good edit mate!!! And those extended shackles are just the kitty!! :D
Really detailed info there, how about some side on shots? See how she sits? :D
L200Lee
Postby van mann » Sun Aug 07, 2011 10:22 pm
This is the longer bolt i needed.
Now all fitted,pic shows the original position but i have used the centre hole,could make the van higher by using the bottom hole if carrying something heavy and only takes 5 minutes..
And heres it all finshed.Painted my rims and facelift bumpers so you get the finished article.
Having driven it to Ford fair today it wasn,t as harsh as other cars iv,e lowered.Very happy as all in it,s cost me £80
van mann
Postby van mann » Sun Aug 07, 2011 11:29 pm
Before and after pics.
Before:
After:
van mann
Postby jonny s » Sun Aug 07, 2011 11:34 pm
looks great!
how does it handle now??
jonny s
Postby NikFrisbee » Sun Aug 07, 2011 11:35 pm
Top work mate!!! Really nice van!!! Think you have a long list of people wanting the same done, if your offering out your services!! If so add me to the list..
220LX-110psTuningBox-PP Decat Pipe-LongLife SS Exhaust TwinTailPipe-K&N Filter-18'' STAlloys-Heated Screen/Mirrors-TOAD-Mk3MondyHandles-Zetec S SteeringWheel-BlackRearLights-RS FocusCenter Console-FactoryFittedFord SatNav/SportsVanFacia
NikFrisbee
Postby van mann » Sun Aug 07, 2011 11:39 pm
jonny s wrote:looks great!
I was quite surprised.Not too bumpy and doesn't bottom out.
van mann
Postby van mann » Sun Aug 07, 2011 11:42 pm
NikFrisbee wrote:Top work mate!!! Really nice van!!! Think you have a long list of people wanting the same done, if your offering out your services!! If so add me to the list..
If i had an unlimited supply of Focus rs springs and rear beams i would do loads of these, but has took me about 6 weeks to source all the parts and do the fabrication.Iv,e used all secondhand parts to keep cost down.
van mann
Postby NikFrisbee » Mon Aug 08, 2011 12:12 am
I have all the parts ready to go!! :wink:
NikFrisbee
Postby Mylee » Mon Aug 08, 2011 11:58 am
How about posting the plate sizes please?
Mylee
Postby AlexB » Mon Aug 08, 2011 12:40 pm
wow that looks sick !, i am defo gonna do bumpers like yours lol, never thought white could look so good just need some money now haha
AlexB
Postby NikFrisbee » Mon Aug 08, 2011 1:26 pm
Right I'm going to have a go at doing this. May take me a few months but I have the front set up ready. On the rear axel, just thinking out loud. Would any other rear axel fit, maybe focus? I'm going to try and find one and while im at it, could one with rear discs be fitted instead of drums or would this be a pain in the arse to fit, what would be involved .. Also are they called leaf spring shackels, as I need to get a set to fabricate the drop extender on to..
NikFrisbee
Postby ginsters » Mon Aug 08, 2011 4:14 pm
massive round of aplause!!
top job looks sh*t hot
the red ones go faster...
53 plate 75ps lwb
vantunner remap and all the other jazz
unfortunately the doors aint as great as the caddy
north wales where the the men are men and the sheep are scared!
ginsters
