Windshield MK1
Windshield MK1
Postby philippetransit » Tue Oct 11, 2011 1:30 pm
Hello everyone,
I'm getting worried about a leak underneath the windshield rubber of my Mk1, as far as I can tell it only leaks when driving through rain, so it's not leaking when parked.
There's water on top of the dashboard and it leaks through under my glove box (right hand side). Checking it out I found some rust and small holes underneath the dashboard where the windshield meets the dash. I'm not sure what to do since the rubber seal seems to be in an ok state, I noticed there are some marks where supposedly they (previous owner/garage) pryed some tool in to remove the windshield (not sure it has been replaced at some point but looks like it has been). I really want to avoid corrosion damage since overall there's hardly any rust or corrosion damage. I did have a problem with water coming through the windshield rubber onto the dash whilst being parked, I filled it up with silicone and since then no water leaks anymore but driving through the rain the water comes through. Should I get somebody to kit the whole windscreen or should I have it removed and fit a new rubber. I'm afraid they're going to break the windshield...
Please advice!
Thank you all in advance for replying!!!
It was love on first sight with my Transit MKI
philippetransit
Re: Windshield MK1
Postby Neil » Tue Oct 11, 2011 3:13 pm
rubber breaks down with age lets water in starts to rot the screen surround,, its a common repair you may find a nasty rotten surround when you remove the screen and rubber, in the uk new screens and rubbers are available
Neil v6
Neil
Re: Windshield MK1
Postby Muttley » Tue Oct 11, 2011 4:59 pm
Yes, as Neil says, you will have to bite the bullet and remove the screen. Be prepared for varying amounts of rust in the surround :( The screen comes out easy enough and if you are unlucky enough to break it I have some screens and rubbers :wink:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Re: Windshield MK1
Postby Neil » Tue Oct 11, 2011 5:07 pm
i was amazed how easy they do come out :shock: and how easy it was to put back
Neil v6
Neil
Re: Windshield MK1
Postby Luke » Tue Oct 11, 2011 6:51 pm
the toughned glass screens come out easy but the laminated ones always seem to break :x :)
Re: Windshield MK1
Postby philippetransit » Tue Oct 11, 2011 7:00 pm
Thanks for the comforting advice you guys! I'm guessing this won't be a " only a few hours" project, somehow I just needed that little push to get started!
I'll keep you all posted on the progress!
Cheers,
Philippe
philippetransit
Re: Windshield MK1
Postby baconsdozen » Thu Oct 13, 2011 8:06 am
The laminated ones are harder to do in that they crack relatively easily,if the rubbers rotten (and you say yours isn't) you can cut it with a knife to make removing the screen easier.
Comma used to do some stuff called "Seek and Seal" I've used it with success some while back but haven't seen any recently.
For leaks where it just trickles in (rather than being forced in by air pressure or blasted in from the wheels) ordinary boot pilsh rubbed in the holes works.All a bit temporary though,its probably time to take the screen out.
baconsdozen
Re: Windshield MK1
Postby Vandalism » Fri Oct 14, 2011 11:28 am
im having the same problem with a leak, water round the dashboard- im putting it down to the holes in the roof where the flashing lights use to be..ive only put some electrical tape over the holes :lol: :oops:
Re: Windshield MK1
Postby conrod » Wed Oct 19, 2011 6:39 am
Vandalism wrote:im having the same problem with a leak, water round the dashboard- im putting it down to the holes in the roof where the flashing lights use to be..ive only put some electrical tape over the holes :lol: :oops:
You need silver tape then, its what I used over the roof holes where the lights used to be on my ex Police van; watertight! :D
conrod
Re: Windshield MK1
Postby Vandalism » Wed Oct 19, 2011 9:46 am
thanks conrod - is there a spesific name for it and would you apply it to the inside or outside of the van :)
Re: Windshield MK1
Postby conrod » Wed Oct 19, 2011 10:48 am
It is aluminium foil tape, I am not sure what else you would call it? Stick to the outside, and you can also stick it on the inside over the hole for double protection. Hardware stores should have it, just cut out to shape before sticking it on. Better if you can get the stuff that has the paper backing that you peel off, makes cutting it much easier.
conrod
Re: Windshield MK1
Postby Vandalism » Wed Oct 19, 2011 11:01 am
ok thanks ill look into that :)
Re: Windshield MK1
Postby conrod » Wed Oct 19, 2011 12:09 pm
conrod
Re: Windshield MK1
Postby Vandalism » Wed Oct 19, 2011 2:13 pm
ahh yes i recognise the tape now, thanks :)
Re: Windshield MK1
Postby joereds » Sat Nov 05, 2011 7:14 pm
Hi,
Is it still possible to find the rubber which goes for the rear window and the side sliding windows on a Ford transit Custom Mk1 1972?
joereds
Return to Mk 1 & 2
