ginsters wrote:theres nothing wrong with this method even volkswagon approve the same sytem on the caddy,it may be made by a big company but the principles are the same
it been done for years on all sorts,never heard of it going wrong
Brit 50 wrote:ginsters wrote:theres nothing wrong with this method even volkswagon approve the same sytem on the caddy,it may be made by a big company but the principles are the same
The mahusif difference is they were designed that way, stress loading on the bolts have been calculated for that design, the reverse is true for the connect, yes it may be true that the bolts won't break but they are not being used for what they were designed for, if, god forbid, someone does have an accident then the whoever supplied the parts, even if it's via an Internet forum, could be in big trouble with the law. If you supply parts for a vehicle you need certain things in place or your in the firing line, and you will need to prove they were fit for purpose. Not being funny but any engineer could find fault with the parts, especially welded ones, was the welder coded? Why are the parts welded and not made new in one piece? Etc etc
Supplying parts is a minefield legally, it's all fun until something goes wrong. As for insurance, you won't get any if your van is lowered in this way and you inform them, they will want an engineers report and it won't be favourable. If you were to have a big accident, even if it was not your fault, and your insurance co does not know of the lowering or the other parties insurance finds out its lowered then your insurance is void, you are personally liable for the other parties losses and injuries and you will get hit big time in court for driving an uninsured vehicle etc etc.
Years ago you could do stuff like this and it wasn't a problem, things have changed hugely, and everyone loves litigation these days!
van mann wrote:Rear u bolts will be over engineered by FORD.If a load capacity is 1000kg they won't be designed to snap at 1100kg.More likley to be at around 2000kg or even more.These are 14mm high tensile steel u bolts not 3mm chocolate ones.The bolts at either end of the leaf spring into the body that take the spring weight are only 15mm.
Lets here from people that have actually done this mod and not armchair pundits spreading doom and gloom that don,t know oen end of a spanner form another.Makes no odds to me either way.Lower your van or keep it standard,it's up to you.I didn,t get into this to make money,just to help other connect owners out as the biggest question on this forum is" HOW DO I LOWER THE REAR OF A CONNECT"?.
As for insurance,make sure you notify them about your alloy wheesl,colour coded bumpers,mirrors,different seats because if you make it more attractive to thieves and don,t tell them,insurance VOID.
Mylee wrote:Brit 50 wrote:ginsters wrote:theres nothing wrong with this method even volkswagon approve the same sytem on the caddy,it may be made by a big company but the principles are the same
Sorry, but you are wrong. The VW ginsters talks about wasn't 'designed that way' as you put it. It has the same standard set up as the connect. VW approve the method of modification. i.e the axle flip
Yes you will get insurance. I've already done so, no engineers report required. Don't scare people.
Welders are coded to specific tasks, i.e pressure ratings, material ratings or specialist environments for example, I doubt the robot that welded the 1000's of original plates on the 1000's of original axle's was coded, but hey you never know
Brit 50 wrote:van mann wrote:Rear u bolts will be over engineered by FORD.If a load capacity is 1000kg they won't be designed to snap at 1100kg.More likley to be at around 2000kg or even more.These are 14mm high tensile steel u bolts not 3mm chocolate ones.The bolts at either end of the leaf spring into the body that take the spring weight are only 15mm.
Armchair pundit lol
Ok, enlighten us with your wisdom, why are the rear spring brackets not supplied made as one piece but are sold to be welded to the original by anyone who thinks they can stick two bits of metal together with all the inherent problems that involves? How will the welded brackets perform with lateral loading as the metal has altered its strength in the middle of the bracket due to the welding process? Why would you weld two bits of metal together to support your springs when surely one completely new part would be so much safer? Would you advise holding the axle in a jig while applying copious amounts of heat to one side of the axle when welding the new brackets to it? How does this modification you are selling the parts for affect the scrub line? (yeah google it to find out what it means) know one end of a spanner, ha!
You may feel that you are 'just helping connect owners out' but if you are not an engineer and do not even have the basic understanding of how suspension works then you are a danger to others. The BIG question on this forum should be......
How do I lower my connect SAFETLY!
van mann wrote:Brit 50 wrote:van mann wrote:Rear u bolts will be over engineered by FORD.If a load capacity is 1000kg they won't be designed to snap at 1100kg.More likley to be at around 2000kg or even more.These are 14mm high tensile steel u bolts not 3mm chocolate ones.The bolts at either end of the leaf spring into the body that take the spring weight are only 15mm.
Armchair pundit lol
