L200Lee wrote:Andy: the front setup is a pain in the arse, you can try the passion ford forum for the springs as they usually have a mk1 rs being broke, or a few spares. OR, Mylee was starting a group buy for some custom springs that where basically the same profile and compression rate as the RS ones but with connect tops, so no need for cups and bearings, drop him a pm to see if it's still available.
Hope that helps
valetech wrote:have spoken to my ford dealer today.have been told the mk 1 rs runs the same setup as a standard focus but just lower springs
so you can use the standard top cups (part number is the same for rs and standard) £26 each from fords or use your local breakers
springs- try using lowered springs for a standard focus or ford can supply you rs spring for £80 each
valetech wrote:Hope my Ford dealer is right
van mann wrote:valetech wrote:Hope my Ford dealer is right
He is right.All focus models cups,mounts and bearings are the same.Just the focus rs springs are different.I got 2 focus legs from the scrapyard for £30 and FOCUS RS springs off ebay for £30
L200Lee wrote:
I think your looking at about 40mm lower on the front.
Ps: Paul your right about the standard focus tops and bearings, I asked the same question to my local ford dealers
So the RS front spring lowers the connect by 40mm - is that all ?
Could the standard connect front spring just not get cut down ?
Anyhow, looks like i'll be getting some standard focus spring tops and bearings from the breakers and some focus lowering springs, i wonder if focus -35mm springs will be ok ?
valetech wrote:
No you can't cut the springs down unless to want to fail the mot
35mm lowering springs will do the job
Mylee wrote:Do a search, one guy on here cut his front springs to match the rear end lowering. Looked good, if a little to low.
A little while after, he reported that the van drove like a pig and had two leaking front shocks due to them bottoming out.
valetech wrote:van mann wrote:valetech wrote:Hope my Ford dealer is right
Did you put the springs from the legs with the rs ones to see the differents? Is it just the height?
