All About FLER
Re: All About FLER
Postby transitandy » Wed Sep 28, 2011 8:36 pm
Thats one hell of a unit 8) 8)
Re: All About FLER
Postby MinorMatt » Wed Sep 28, 2011 8:49 pm
Ake - yeas and you have bloody good eyesight! The focus originally came from Inverness I believe ;)
The scary thing is that its already fairly full, and Fler isn't inside yet :shock:
Re: All About FLER
Postby MinorMatt » Sat Oct 01, 2011 7:37 pm
today I had a little play today.
The LPG is now working except at idle - I have to modify the tank mountings slightly to make it legal though.
I can live with it at the moment as almost all my mileage is motorway/dual carriageway but I would like to get it sorted. I suspect changing the pipework from the splitter to the mixers would help but I should be able to get to the weekend build on gas :)
Re: All About FLER
Postby MinorMatt » Sat Nov 12, 2011 6:13 pm
Van has now run out of MOT...
BUT I have got the gas running, its a little lumpy at Idle but it does idle!
The only think is there is quite a lot of white smoke on petrol and gas so I think I have a head gasket problem :(
Re: All About FLER
Postby belly » Sat Nov 12, 2011 8:13 pm
Cool shed Matt wish i could find one round here like that :)
belly
Kaiser Chief
Re: All About FLER
Postby MinorMatt » Sat Nov 12, 2011 9:26 pm
its not round here - its in Sussex...
At the moment there are 4 minis, a minor pickup, 2 trailers and a load of spares & Tools!
Re: All About FLER
Postby belly » Sun Nov 13, 2011 3:54 pm
MinorMatt wrote:its not round here - its in Sussex...
Yeh I know :wink:
belly
Kaiser Chief
Re: All About FLER
Postby MinorMatt » Fri Nov 18, 2011 7:22 pm
Put a small patch on the front cross member (about 2.5" x 1.5") this morning, swapped the brake drums and took it for an MOT...
For the first time in my ownership I have had to take it away from the MOT station without a pass :(
The tester rubbed one of my brake pipes (quite aggresively) with sandpaper - and made a hole :(
There were advisories on another corroded brake pipes, corrosion on a front flexi and slight play in the steering rack.
He was looking at it for an hour and 20 minutes :shock:
Ready to go back for restest now
Re: All About FLER
Postby belly » Fri Nov 18, 2011 7:38 pm
:( Better to happen there though than coming of a sliproad loaded with Moggy/Transit parts and lose brakes :shock:
belly
Kaiser Chief
Re: All About FLER
Postby MinorMatt » Fri Nov 18, 2011 7:50 pm
Theres rarely anything in it...
Still had the front brakes and handbrake :wink:
Re: All About FLER
Postby belly » Fri Nov 18, 2011 7:53 pm
oh ok bummer then :( But hey on the bright side it's now even better 8)
belly
Kaiser Chief
Re: All About FLER
Postby MinorMatt » Sat Nov 19, 2011 9:39 am
Retest.... Passed
Re: All About FLER
Postby transitandy » Sun Nov 20, 2011 12:02 am
well done matt :)
Re: All About FLER
Postby MinorMatt » Sun Nov 20, 2011 1:15 am
I'm quite dissapointed that I needed a retest this year :(
Worst looking van on the forum - but first time it has ever had to be taken away from the MOT station without a pass cert since I have had it (4 years)
Re: All About FLER
Postby madbri » Sun Nov 20, 2011 6:06 pm
i run u a close 2nd then :twisted: :twisted: :twisted: thought mine was dog :twisted: :twisted:
madbri
