ford sony radio fit in connect???
Postby jd-lee » Thu Nov 17, 2011 9:52 pm
does anyone know if this stereo fits in the 08 plate connect??
2007 Transit GLX 130 SWB - Now reprogrammed ECU to 140bhp and retuned to 170bhp by the man himself... vantuner - upgrade to six speed and has All the toys ;-)
Custom made front grill
jd-lee
Re: ford sony radio fit in connect???
Postby blue estate » Thu Nov 17, 2011 10:00 pm
Yes :D but why don't you look for the newer ford Sony with the buttons across the top :wink: just search under mk7 fiesta
you'll notice the difference over the standard 6000cd
blue estate
Postby trigger » Thu Nov 17, 2011 10:03 pm
Mk5 Transit the daddy
trigger
Postby jd-lee » Thu Nov 17, 2011 10:05 pm
jd-lee
Postby trigger » Thu Nov 17, 2011 10:07 pm
Same as the one i posted, you can get them a lot cheaper than £250 tho
trigger
Postby jd-lee » Thu Nov 17, 2011 10:35 pm
theres loads of the one u posted. but they dont have the surround to fit in the hole. do u know if u can buy them separate mate??
jd-lee
Postby trigger » Thu Nov 17, 2011 11:43 pm
I would have thought the surround is available seperately, you could try Fords or even late model breakers, i want to put one of these units in my mk7 Fiesta when i have the cash
trigger
Postby Graham Taylor » Thu Nov 17, 2011 11:44 pm
Dont think this would fit 05 plate would it? If not anyone know of a similar DAB thats a direct fit?
Graham Taylor
Postby trigger » Thu Nov 17, 2011 11:53 pm
Someone did a thread on here about modding an early Connect dash to fit the later stereos
trigger
Postby Graham Taylor » Fri Nov 18, 2011 6:31 pm
Yep read that. Fair bit of messing around. Found this on ebay, says it will convert the older Connects to accept double din headsets.
http://www.ebay.co.uk/itm/250885158427? ... 1438.l2649
Graham Taylor
Postby ake » Sat Nov 19, 2011 9:28 am
That will reduce it down to fit a single din, it will not however increase the size of the hole to fit a double din
Postby Graham Taylor » Sat Nov 19, 2011 10:22 am
ake wrote:That will reduce it down to fit a single din, it will not however increase the size of the hole to fit a double din
Thats what I thought however it does clearly state "These adaptors will convert the non din-sized aperture left after removing the factory stereo to a single/double din size ready for head unit installation. (JVC, Kenwood, Sony etc)"
Load of bollox?
Graham Taylor
Postby ake » Sat Nov 19, 2011 3:41 pm
I reckon so as the hole for the earlier stereo is din and a half, the later one is double din
Postby paul2012 » Sat Oct 20, 2012 5:54 pm
For sale, full working order
Sony Gen 2 MP3 / CD player - Bluetooth / Voice control Compatable Ford Part No:- 7M5T-18C939-CF
Fits all mk2 connects from 2006-2009 - can also fit mk1 connects with the mk2 centre console fitted :wink:
see post here
viewtopic.php?f=54&t=116284
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
