2.5di turbo on veg oil as a fuel
Postby greg123 » Fri Jul 08, 2005 8:50 am
bortaf wrote:what about an iveco lump? they are rated at 125 aint they or are they a non ford unit (like the rest of the van) :lol:
Absolutely! The old 2.8 di turbo 4 cylinder lump in the low tune is 110/125 hp, or 145hp for standard intercooled. With mild tuning it's 160hp. It also has a Bosch pump suitable for running on oil. The new 3.0 litre engine that replaced it is rated up to around 170hp from the factory.
The engine is used in the Iveco, Renault Master, Fiat Ducato, Citroen Relay, Peugeot Boxer (latter 3 all Sevel vans) and Vauxhall Movano as well as sold for industrial/marine use.
It also has the distinction of holding the record for camper van mpg at SBMCC, with 3 models averaging over 30mpg - they are extra long (about 4 ft longer than a LWB transit) extra high roof variants and still got that mpg!
The engine isn't a ford and as you say the van doesn't share much. The Iveco is more like a truck in construction, much heavier built than most other vans - things like oversized track rod ends with built in grease nipples etc.
I wouldn't want an Iveco as the floor is way too high and the cab is very 'truck like'. However the 2.8 Iveco engine variant of the SWB Sevel range I am interested in. Just a shame you can't get the automatic in the UK! The van has a very low floor and is wider than the Transit (6'3 internal headroom on the semi high roof, over 7' on the high roof).
It doesn't come with all the kit of the Tourneo though!!! I think I'm going to have to pick a van and then build it up to Tourneo spec, at least if I go for a 2.8 sevel I'll have a stonking strong drive with 80mph up a hill overtaking ability (on vegatable oil of course!).
Greg.
Independant VW/Audi Vehicle Engineer, qualified 18 years (tdi & vegoil specialist)
Ex IT tech, former IT Support manager, Webmaster
Occasionally return to London as a SIA Security Instructor & consultant!
greg123
veg oil
Postby MRspivvy » Thu Jul 28, 2005 3:38 am
I have run a 94 diesel transit 80 on a 70/30 mix of diesel and veg oil,(to avoid the smell of frying really. it will run fine on 50/50) no probs at all.
MRspivvy
Postby madmark » Thu Jul 28, 2005 4:30 am
guys thanks for the info , and geoff i have now seen a 80ps engine in grahams blue and white high top! :shock: this is a 94 L reg! the first one i have ever seen! i know when i orderd a van in 99 they only gave me a 76ps option or turbo 85ps for around £1200 :shock:
Postby gazza » Tue Aug 09, 2005 11:48 am
with the price of diesel as it is now i have tried putting veggie oil in on a run to wales. put three gallons in and filled the tank full. ran a dream, gonna try a bit more soon as we are of to cornwall
gazza
Postby MrMPuk » Tue Aug 09, 2005 12:34 pm
Hope your paying the 23p tax on that untaxed fuel or how ever much they are stinging us now! Really not worth the rist at the moment with the old bill being the way they are!
Postby MRspivvy » Tue Aug 09, 2005 12:47 pm
MrMPuk wrote:Hope your paying the 23p tax on that untaxed fuel or how ever much they are stinging us now! Really not worth the rist at the moment with the old bill being the way they are!
yes, especially driving a van. big big fine if you get caught.
MRspivvy
Postby Luke » Tue Aug 09, 2005 12:54 pm
In all my years of driving vans, cars, campers and 7.5T's ive never once been stopped and had my tank dipped!! :D worth the risk i'd say :wink: :lol:
Postby MRspivvy » Tue Aug 09, 2005 12:56 pm
depends where you live I suppose, there was a huge police clampdown in LLanelli a couple of years back as all the local taxi drivers were using veg oil so ministry check points were everywhere. I have never been stopped either though
MRspivvy
Postby MrMPuk » Tue Aug 09, 2005 1:17 pm
They have regular checks where I live on vans they stop them and the minstry do all there checks then the DSS do theres.
Postby gazza » Tue Aug 09, 2005 1:58 pm
the way i understand it is you declare it at the end of the tax year, if you do get dipped ypu can only be taxed on the amount in the tank? also they are looking for red rather than veggie or heating oil. i dont think they do a chemical analasis of whats in your tank do they?
gazza
Postby MRspivvy » Tue Aug 09, 2005 2:48 pm
gazza wrote:the way i understand it is you declare it at the end of the tax year, if you do get dipped ypu can only be taxed on the amount in the tank? also they are looking for red rather than veggie or heating oil. i dont think they do a chemical analasis of whats in your tank do they?
not sure how the tax thing works, but as a HGV driver I have had my tank dipped on the truck a few times, no they dont do a chemical analysis (although they DO have the facility to do this if they have reasonable suspicion) normally they take a sample and they can tell just by looking at it what you are running on. as you say its more for red diesel than anything else, but these days some of the cowboy operators are using "laundered" diesel (basically red diesel that has had the dye removed by a chemical process. I wouldnt use it, they add lots of acid to burn the dye away and it kills the engine!) and they are checking for this.
this is more popular in other countries, in Ireland they have green diesel instead of red, its called "leprechaun piss!" :lol:
MRspivvy
Postby brocky1978 » Tue Aug 09, 2005 4:13 pm
as far as im aware as long as you dont use pure cooking oil , whats the difference between mixing it yourself and the bio diesel out of the pump, plenty of people use that now!
brocky1978
Postby MRspivvy » Tue Aug 09, 2005 4:15 pm
brocky1978 wrote:as far as im aware as long as you dont use pure cooking oil , whats the difference between mixing it yourself and the bio diesel out of the pump, plenty of people use that now!
the only difference is that pump bio diesel has had the excise duty as a road vehicle fuel paid. veg oil you put in yourself hasnt.
MRspivvy
Postby brocky1978 » Tue Aug 09, 2005 4:17 pm
yeah but whos goin to know thats what i'm saying!
brocky1978
Postby MrMPuk » Tue Aug 09, 2005 5:03 pm
Like I say they are always doing checks around my area and I know for a fact that they do now check for the use of veg oil since that is where the biggest saving is at the moment!
