Radio Codes
Re: Radio Codes
Postby trigger » Wed Dec 14, 2011 2:49 pm
Not sure, i did read someone on here mentioned there's a way to get 3 more trys at it but can't remember the post
trigger
Radio Codes
Postby Highlander250469 » Wed Dec 14, 2011 6:31 pm
I posted this on the Scorpio forum many years ago, explains it all fully..
To obtain your radio code you will need the serial number of the radio, usually shown on the label on the right side of the radio.
eg. M123456
The radio will need to be at least partially removed to see this using the correct removal keys.
A request on the forum showing your serial number will usually produce the code fairly quickly.
Or the software can be downloaded from HERE
When running the software the following appears :
Enter your serial number then click on the large No. 5 Preset button on the bottom to generate the code.
To exit the software click on the large on/off button on the left
To enter the code on the radio use the large preset buttons on the bottom of the radio (1-6) RDS 4000, 5000, 6000 etc.
eg. Code = 2487
press button 1 to cycle through the numbers until 2 is displayed.
press button 2 to cycle through the numbers until 4 is displayed.
press button 3 to cycle through the numbers until 8 is displayed.
press button 4 to cycle through the numbers until 7 is displayed.
press button 5 to enter the code.
If 3 incorrect attempts are made there will be a 30 minute delay before you can try again, the key has to be in the ignition position 1 during this time, removing it will reset the timer.
After 10 wrong attempts the display will show LOCK 10
Holding button 6 while turning the radio on will give you a further 3 attempts.
If these three are entered incorrectly the display will then show LOCK 13 and you will now need to get it reprogrammed
Highlander250469
Re: Radio Codes
Postby taz666 » Wed Dec 14, 2011 9:38 pm
[quote="trigger"]There's a guy on ebay who can do the V codes for £3, i used him when i needed the code for the 6000 cd in my Fiesta van[/quote]
you wasted £3, i do them for free ;)
taz666
Ford Technician
Re: Radio Codes
Postby Geoff Ingle » Fri Dec 16, 2011 5:28 pm
The welder who repaired my exhaust box on my 2005 Mondeo disconnected my battery and I cannot find the radio codes. The radio serial number is M055879.
If no one can help me with the code, a link to where I can find them would help. Thank you
Geoff Ingle
Geoff Ingle
Re: Radio Codes
Postby Highlander250469 » Fri Dec 16, 2011 5:50 pm
1080
Highlander250469
Re: Radio Codes
Postby trigger » Fri Dec 16, 2011 8:25 pm
[quote="taz666"][quote="trigger"]There's a guy on ebay who can do the V codes for £3, i used him when i needed the code for the 6000 cd in my Fiesta van[/quote]
you wasted £3, i do them for free ;)[/quote]
I didn't know that then, you never mentioned it on here before
trigger
Re: Radio Codes
Postby Geoff Ingle » Sat Dec 17, 2011 10:19 am
Thank you Highlander250469 you are a star.
Geoff
Geoff Ingle
RADIO CODE
Postby shaker-maker » Sat Dec 17, 2011 7:58 pm
Hi there,
Can anyone help with a radio/cd code for a 6000ne model, the serial number is - M381849 and is there a procedure for entering the code.
Many thanks in advance to any one that would know this.
Shaun
shaker-maker
Re: RADIO CODE
Postby friertuck » Sat Dec 17, 2011 8:12 pm
try 8393
Chips chips and more chips
friertuck
Re: RADIO CODE
Postby shaker-maker » Sat Dec 17, 2011 8:26 pm
Thanks very much friertuck, that code was good.
Shaun
shaker-maker
radio code
Postby davew2 » Sat Dec 17, 2011 8:32 pm
Hi all can someone get me a code for 4000 RDS serial number M032263 thanks in advance :D
If it ain't got leaf springs it in't a commercial
davew2
Re: radio code
Postby APH » Sat Dec 17, 2011 9:27 pm
Hi, you should have posted in the radio codes section, but here it is anyway:
Try 5636
Andy :D
(\__/)
(")_(")
this is bunny
APH
Re: radio code
Postby davew2 » Sun Dec 18, 2011 12:10 am
Cheers worked a treat will post in radio section next time :oops:
davew2
Re: radio code
Postby Altransit » Sun Dec 18, 2011 1:23 am
davew2 wrote:Cheers worked a treat will post in radio section next time :oops:
Moved :!: :D
Re: Radio Codes
Postby trigger » Sun Dec 18, 2011 2:01 am
Where's the radio section?
trigger
