GKandR4CH wrote:But what if it was removed and the new relevant pieces put on? Who would know it had been removed in the first place??
I think most MOT testers should realise that if the vans not got abs then it would normally have a load sensing valve fitted. Ford did fit the valve for saftey reasons. I would be very careful running around with the load sensing valve disconnected I don't know which way the valve works without checking it but you could either have no rear braking or have too much rear braking.
I got my first connect back in 2002 but it had a knocking noise from the rear brakes when I took it back to the dealers they told me the sensing valve wasn't adjusted correctly so they adjusted it under warrenty. I didn't think they had adjusted it correctly so I tested it on some MOT brake rollors to find it had no rear brakes.
GKandR4CH you've got abs so your axle flip and disc conversion should be fine but it would be interesting to see the brake readings when you next get it MOT'd.
I'm not having a dig at anybody but just be careful guys.
