DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: ETIS Info Please
Postby TJ101 » Sat Jan 21, 2012 9:38 am
Mike Spence wrote:Yes, go to http://www.etis.ford.com/ select vehicle and pop your reg number in.
Thank you Mike 8) :D
TJ101
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby adeenuf » Sat Jan 21, 2012 11:11 am
could someone kindly supply info on my van please, thanks, mark
Y506 WGK
I'am not alone.... the voices in my head keep me company.
An Essex boy in Scotland
adeenuf
Postby henry harvey roofing » Sat Jan 21, 2012 10:52 pm
Hi, saw this van due for sale at auction SA10ZZX estimate £8800 Plus vat and buyers fees. can someone tell me a bit about it and do you think its worth that sort of money.
07 reg 300 lwb med roof
12 reg 260 swb low roof 125 limited
Postby henry harvey roofing » Sat Jan 21, 2012 11:02 pm
sorry just seen previous posts and looked up etis myself, thanks
Postby adeenuf » Mon Jan 23, 2012 5:19 pm
adeenuf wrote:could someone kindly supply info on my van please, thanks, mark
Y506 WGK
no worries done it from previous post, thanks for the link....
adeenuf
Postby gogsboy » Mon Jan 23, 2012 9:19 pm
How accurate is Ford ETIS.
I'm not a van expert but according to my V5 my van is a SWB which not convinced it is and it has also been filled out as a SWB M/R in the service book by the supplying dealer, however I've been in a M/R and can't stand up yet I can in my van.
Reg is GR04 XTH is someone can take the change out of that :)
gogsboy
Postby jolly olly » Mon Jan 23, 2012 9:27 pm
gogsboy wrote:How accurate is Ford ETIS.
Etis is this accurate :lol:
Transit 2000-2006, 2.0L Duratorq DI (85PS), Diamond White 73
VIN Number: WF0VXXBDFV4D73206
Registration Number: GR04XTH
Registration Date: 26.07.2004
Registration Country: GB
Registration information for your currently selected Vehicle:
Registration Number: Registration Date: Registration Country: Modified Date:
GR04XTH 26.07.2004 GB
18.01.2012
Primary Features
Build Date: 02.07.2004
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 280S Series
Engine: 2.0L Duratorq DI (85PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Fabric: Stylize (-G-C
Life is not a dress rehearsal
jolly olly
Postby gogsboy » Mon Jan 23, 2012 9:32 pm
Thanks very much, the V5 shows 26th as the reg date but the dealer has written 23 in the book
So does it say in there is it's a SWB/MWB/LWB and type of roof in code language :)
gogsboy
Postby ake » Tue Jan 24, 2012 7:48 am
Series: 280S Series - The S means SWB
Postby davew2 » Tue Jan 24, 2012 4:44 pm
hi all can any one get details of this YJ51 GNP i can't :? :oops:
thanks in advance Dave
If it ain't got leaf springs it in't a commercial
davew2
Postby jolly olly » Tue Jan 24, 2012 8:18 pm
davew2 wrote:hi all can any one get details of this YJ51 GNP i can't :? :oops:
Unable to Locate Information for the Vehicle Data
We are sorry, but no information could be found for the VIN/Registration number you entered - YJ51GNP
jolly olly
Postby d8veh » Wed Jan 25, 2012 9:57 am
My reg is RK53 YOX
Could someone find the details - in particular whether it was electronically limited to 60 mph.
d8veh
Postby Altransit » Wed Jan 25, 2012 10:02 am
d8veh wrote:My reg is RK53 YOX
Transit 2000-2006, Duratorq DI 2.4 (90PS), Moondust Silver (Metallic)
VIN Number: WF0LXXGBFL3T64442
Registration Number: RK53YOX
Registration Date: 05.11.2003
Primary Features
Build Date: 28.08.2003
Series: 350L Series
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.88
Territory: (+)"GB"
Paint: Moondust Silver (Metallic)
Interior Fabric: Cordwain Vinyl (G-V)
Minor Features
With High Roof
With Rear Mudflaps
With Front Mudflaps
With Full Partition - Steel
LH Sliding Side Cargo Door - High
With Hinged Rear Loading Doors
With 270° Cargo Door Check Arms
With Standard GVM Rating
Genk Plant Build
Special Order Paint
With SVO Application/Label
Marketing Level 3
With Rear Blanking Panel
Less Heated Rear Window
With Header Mounted Package Tray
With Complete Rear Hardboard Trim
Flr Cvr-Rubber Ins-Extended
With Partial Headlining - Moulded
With Door Map Pocket
With Front Roof Grab Handle
With Load Space Tie Down Loop
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
With Narrow Body Moulding
With Rear Step - Centre
Less Rear View Mirror
Large Head/Short Arm Mirror
Passenger Lrg Head/Short Arm Mirror
Less Drivers Seat Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Trailer Towing Attachments
Fleet Key
With Door Dead Locks
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
With Grey Plastic Rear Bumper
With Driver Air Bag
With Jumbo Body Pack
With Spare Tyre Security Package
With Single Rear Wheels
215/75R 16C BSW Tyres
Less Engine RPM Control
Cold Start -15 Deg C
With Improved Attitude/Ride Height
With Standard Rear Suspension
4 Wheel Anti-Lock Braking System
With Brake Only Traction Control
With Manual Clutch
Less Rear Seat Climate Control
With Recirculating Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
With Anti-Theft Alarm
Standard Duty Battery
Drivers Seat Rechargeable Battery
With Radio Pre-Equipment Pack 1
2000NT Series
With Load Compartment Lamp
Less High Mounted Stop Lamp
Less Roof Mounted Turn Signals
With Manual Headlamp Levelling
With Battery Cut Off Relay
With Auxiliary 6 Fuse Box
Postby d8veh » Wed Jan 25, 2012 11:17 am
many thanks
d8veh
Postby vanman08 » Wed Jan 25, 2012 3:55 pm
Hi guys and girls could anyone do an etis on my van please
reg number is KB O5 LRV
vanman08
