24v 2.9 V6 Cossie lump into a Mk3 190
Postby dipstick » Mon Oct 23, 2006 12:27 pm
I have finally got most of the 'hard' bits collected up, so i thought i would start the transplant ....
I have a 1998ish 24v BOB motor from a late model Scorpio and a 2.9 12v (c/w adapter plate and MT75) from a Police-spec transit.
The two engines are next to each oter on my drive, so i am currently transplanting things, flywheel, adapter plate, engine mounts from the 12v to the 24v motor. problems with oil returns from the cosworth heads, and remote filter housing have caused headaches.....but nothing that an angle grinder and some slicone can't fix... :)
if i can i will post some photos soon......
dipstick
Cosworth Powered
Cosworth Powered
Postby madmark » Mon Oct 23, 2006 12:35 pm
:lol: yep dont forget the picks mate looking forward to seing them! :wink:
Postby 24vMk2 » Mon Oct 23, 2006 6:07 pm
A BOB engine! :shock:
How are you getting around the PATS system? It wired into everything on a Scorpio, and thats the main reason why everybody fits aa BOA (earlier engine) its easyer to wire up.
But, good luck with the project, and watch the wear on the cam spockets!
24vMk2
Postby dipstick » Mon Oct 23, 2006 11:01 pm
:) when i got the BOB i did not realise that there were two types of Cossie 24v.....
However i am going to use a Megasquirt based system to drive the injectors and the VIS, and use the EDIS for the sparks...
... you live and learn.....
ps how do i post piccies to the forum please?
dipstick
Cosworth Powered
Cosworth Powered
Postby 24vMk2 » Mon Oct 23, 2006 11:10 pm
You can run the BOB engine on the earlier loom and ECU.
Only thing it doesn't do is work the valve in the intake manifold, but theres ways around that.
24vMk2
Postby dipstick » Tue Oct 24, 2006 10:28 pm
... :) yes I did realise that , but i got the motor 'bare' , gas-axed out of the Scorpio, so no electrics, so rather than find an Scorpio ECU i thought i would get one off the shelf and have fun mapping it myself....
I have pulled the 2.5 di motor out of the Transit, with a Maglite and a crowbar...... Does anyone know if you can squeeze the motor and MT75 bolted together back in to the engine bay, or do you have to put the transmission in first and then offer up the motor... ?
cheers, Daryl
ps How do i post pics onto this forum?
dipstick
Cosworth Powered
Cosworth Powered
Postby MrMPuk » Tue Oct 24, 2006 10:52 pm
How to post pictures! If you look it has been answered quite a few times!
http://www.fordtransit.org/forum/viewtopic.php?t=23
Postby 24vMk2 » Tue Oct 24, 2006 11:11 pm
Your only up the road from me, mine have to pop over and have a look at this, if thats ok? :D
24vMk2
Postby dipstick » Wed Oct 25, 2006 10:28 am
... sure, not problem ...... :-)
When you are going to be in the Wrecsam area just give me a shout....
dipstick
Cosworth Powered
Cosworth Powered
testing upload of photo, here goes
Postby dipstick » Wed Oct 25, 2006 10:38 am
12v 2.9 Transit motor and MT75 brought back in the back of trusty renault shed-on-wheels
http://photobox.tiscali.co.uk/album/alb ... o=82843911
dipstick
Cosworth Powered
Cosworth Powered
Getting the 12v 2.9 V6 home and removal of MT75 'box
Postby dipstick » Wed Oct 25, 2006 10:50 am
dipstick
Cosworth Powered
Cosworth Powered
still going ...
Postby dipstick » Sat Nov 04, 2006 6:30 pm
Today i put the adapter plate on the back of the 24v, i had to take off the manifolds, they get in the way of everything.... :(
How has anyone else got round the 'manifold' problems ..? :(
Anyway, connected up the engine crane and tried a first fit to get the Cossie lump into the engine bay......... How do you get the angle right on the motor to get it over the front 'sill' and yet low enough to clear the top of the transmission tunnel....where do you pick up on the motor...?
thanks if any of you can provide any answers....
Cheers :)
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Sat Nov 04, 2006 7:32 pm
On mine i fitted the engine and box separate. Take out the slam panel and it will slide in level. then just drop it downand bolt it on.
try custom he got around the manifold :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
slam panel
Postby dipstick » Sat Nov 04, 2006 8:49 pm
Guy88,
do you mean the removeable front to the Transits, where the bonnet catch is? if this is the slam panel, then , yes, this is removed, but i find that when i back the motor into the engine bay it hits the bulkhead before the engine mounts line up with the chassis... :(
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Sat Nov 04, 2006 9:04 pm
you will need to tip it back line it all up and bolt it in. if you use chain just shorten the front one bu a couple of links. or use a ratchet strap to lift it up :wink: :wink:
as i said in the other post. have you modded the bulkhead :?:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
