My MK5 Minibus Project
Re: Newbie, what do I do next! Can a member pop round?
Postby RonTransitmk5 » Thu Jan 26, 2012 6:13 pm
dieselhead123 wrote:Hi mate and welcome to the forum.
It looks like there is quite a bit of welding to be done there on the old girl, nothing unusual for a Mk5 though.
Cab you weld? Because if you can't then you will be able to by the time your van is done, there are members on here who purchased welders just to do their vans and did a good job.
Most of the repair panels that you need are cheap or can be made easily from flat plate.
I would be happy to inspect and offer advice when I am next over your side of the river, there are other forum members close by who will no doubt be able to assist.
Hi Tim
Never welded in me life, but joined mig-welding forum to find out how.
Love for ya to take a peek when you are over this way rm9 5ba.
Thanks Ron
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
Postby RonTransitmk5 » Thu Jan 26, 2012 6:22 pm
Gonna cut all the rot out & replace with panels or self made sheet metal for the floor & sills, but will plate the chassis as it's only 2-3 small pieces (for now)
On the look out for a clarke welder, auto dark helmet, gas, ect at the mo, it's very hard when you cannot drive anywhere yet.
Found a Clarke Pro 90, but may be a bit underpowered for this project unsure.
Spending the next few days totally stripping out all the plastic/trim/front flooring ect I can, will be getting it up on ramps either Fri/Sat so will then start cutting all the rot away.
Thanks everyone for your messages/comments
Ron
RonTransitmk5
Postby robbie.cee » Thu Jan 26, 2012 6:27 pm
any fridges/freezers dumped locally- beat the scrap men and get cutting! some guys even used pc cases! :lol:
if it does the job and is out of sight then who cares!
WEAR A MASK ARC EYE FOOKING SUCKS 36 hours in darkness for me in fooking agony
then my whole face peeled same as sun burn so guess what it must have done to my eyeballs! :(
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby RonTransitmk5 » Thu Jan 26, 2012 7:12 pm
CH1 wrote:Dont let it get the better of you mate, thought I would post up my tread of my mk5 restoration, might give you some ideas :arrow: viewtopic.php?f=27&t=67521
Many thanks for the link, given me a few more ideas of how to tackle mine :D
How thick was the steel you used?
RonTransitmk5
Postby gavuk » Thu Jan 26, 2012 8:21 pm
If you get arc eye ,normally a few hours after finishing welding ,eye drops like optrex help if its in the early hours (usually is :D ) place damp teabags on the eyes the tannin helps relieve the pain....
As for Sip welders,they do work and are readily available ,but they suffer from wire feed issue's....the power feed to the wire motor and the arc are not seperate and the wire feed suffers as a result ,so consistent results are difficult ,I would urge anyone intrested in welding to pop over to http://www.mig-welding.co.uk....plenty of pages with reviews of welders and mods to sip welders ,,,,,in short they will say on a budget clarke is a clear favourite ,i started with a sealey (red box) which was fine, the sealey yellow box(siegen) are not thought to be as good but that could just be a lack of positive reviews :shock:....wolf ,aldi etc rockwell are not well thought of but check the website for pages of reviews etc ....Gav
gavuk
Postby CH1 » Thu Jan 26, 2012 9:32 pm
Think it was about 2mm thick :wink:
M1 Tyres
Mobile Tyre Fitting Service
Covering the North East
http://www.m1-tyres.co.uk
Currently running:
Mk5 swb 80 with twin SLDs
Mk7 110ps T300 fwd pickup
Mk7 125ps T350 lwb Euro5
CH1
Postby Dawsie » Thu Jan 26, 2012 10:06 pm
robbie.cee wrote:any fridges/freezers dumped locally- beat the scrap men and get cutting! some guys even used pc cases! :lol:
I get filing cabinet separators . You use them to organise your files in one of them office places :-)
They are soft enough to bend over your knee and when you hit it with hammer it goes where its put - painted as well .
once you get it welded at a corner the hammer and chisel and a helper with a large screwdriver or broom stick will get the edges to mate for welding . My fav welding trick is to use the jack and a bit of 4x2" to get the bits of metal touching .
The mot man always puts ' heavily coated in underseal ' as a bad point . I also use 'red stripe'(?) seam sealer' to cover my pidgeon shitty welds followed by underseal .
Dawsie
Postby Highlander250469 » Thu Jan 26, 2012 10:33 pm
I break a few cars and cut large flat rectangle panels out of the roofs, makes lovely welding metal and quite thick.
Take all the advice on arc eye very seriously, at the time you will feel nothing but when you wake up at 4am you won't be able to peel your eyelids apart :lol:
I only ever got arc eye once, you'll never do it twice!! :lol:
Highlander250469
Postby RonTransitmk5 » Mon Jan 30, 2012 1:57 am
Thanks for the tips on Arc eye will take that on board.
Stripped all the interior out & removed the tow-bar & bumper, decided to cut out some of the crap.
The kids think it's great that dad's cutting the van up lol
The wife isn't as impressed
RonTransitmk5
Postby RonTransitmk5 » Mon Jan 30, 2012 3:00 pm
Do you think I should weld a plate over the chassis in the 3rd picture, as I don't feel confident in cutting it out in case the whole thing collapses on me
RonTransitmk5
Postby gravelrash2004 » Mon Jan 30, 2012 7:33 pm
dont worry about chopping that bit out - mine was rotten to the bone there.
you can chop it out and then add a new piece of chassis section. - have a look at my projects 8)
My Projects
150S :- DOHC 2.0 EFI (115PS), Ratio: 5.14
viewtopic.php?f=27&t=66682&start=15
viewtopic.php?f=27&t=97579&p=829640#p829640
gravelrash2004
Postby Muttley » Mon Jan 30, 2012 8:00 pm
Thats one seriously rotten van :shock: I would be careful with repairs to the main chassis, you need good steel of at least 1mm thickness and leave no rust as it will compromise the weld quality. Repairs to the floor must use at least 0.6mm steel and all welds must be continous around the entire panel. I am in Sutton Surrey and I can do you a good price on welding the Chassis and help you learn to weld the flooring if you like :)
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby RonTransitmk5 » Mon Jan 30, 2012 8:26 pm
Muttley wrote:Thats one seriously rotten van :shock: I would be careful with repairs to the main chassis, you need good steel of at least 1mm thickness and leave no rust as it will compromise the weld quality. Repairs to the floor must use at least 0.6mm steel and all welds must be continous around the entire panel. I am in Sutton Surrey and I can do you a good price on welding the Chassis and help you learn to weld the flooring if you like :)
I have sent you a PM
RonTransitmk5
Postby RonTransitmk5 » Mon Feb 13, 2012 4:05 pm
Message to the mod Andyg, can you please update the title to read My MK5 Minibus Project? as this ones a little outdated now, thanks
RonTransitmk5
Postby Altransit » Mon Feb 13, 2012 4:12 pm
RonTransitmk5 wrote:Message to the mod Andyg, can you please update the title to read My MK5 Minibus Project? as this ones a little outdated now, thanks
:idea: Other mods are available :P :lol:
Title edited and thread moved to the progress section :wink: :D
