Mk5 Radio Wiring....
Postby IgorVigor » Thu Feb 02, 2012 5:54 pm
Right, I wanted to ask all of you about the radio wiring...
I have an aftermarket CD player that I've fitted in my transit...
the standard Ford cassette player would work without the ignition on.
the aftermarket CD player (a Kenwood with an adaptor to link it to the transit wiring), works fine, apart from I need the ignition on.
now it has 2 wires (a red and a yellow) that can be swapped over for certain vehicles (mainly VW's)
does the transit require these 2 wires to be swapped over to allow it to work without the ignition on?
if need be, I'll run a new power cable (permanent live)....
IgorVigor
Re: Mk5 Radio Wiring....
Postby robbie.cee » Fri Feb 03, 2012 12:25 am
red one is switched from ign, this one plugs into a single one. the yellow or orange will have 2 sockets, so you can run stereo with ignition off.
just dont get caught out with a flat battery!
if you plug red into yellow then the yellow(perm live to batt) gives the switched red wire a perm feed as if the key glued in ignition :lol:
blue wire goes to power antenna or amplifier remote on terminal
reallly thin yellow MIGHT be illuminaton with headlights
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby IgorVigor » Fri Feb 03, 2012 4:01 pm
on mine the red and yellow wires leave the unit, and before the ISO connector they have a bullet connector and socket.
you can swap the wires over for certain vehicles (VW or example), but you can't double them up without modding the wiring....
I've had a proper look, and the wires from the CD player go to the correct wires on the loom....
the memory wire is permanent live, and it does work (the CD player will resume the song where it was turned off)...
oh well, looks like I need to run a new wire to the unit.....
I want it to work without the ignition on, so I can leave it playing when working on the vehicle....or if I'm sitting in a car park waiting for someone (that sounds a little wrong :shock: :lol: )
oh well, at least its not going to be hard......I have a permanent live wire that runs from the fusebox up past the CD player anyway (it was an alarm wire I believe)
IgorVigor
Postby robbie.cee » Sun Feb 05, 2012 11:36 am
m8 just plug red from stereo into yellow/orange double with the yellow/orange,
thats it!! no wiring needed!!!
yellow perm live into red ign switched== perm usable stereo key in or not!! just mind battery! :wink:
Had
MAKE IT FIT
robbie.cee
Postby IgorVigor » Sun Feb 05, 2012 2:44 pm
I'll do that when I can :)
I'll just have to slide my hand to the radio via the dash tray hole (above the glovebox), so I can get to the supporting bracket :shock:
unless its easy to remove the vent next to the radio....
IgorVigor
Postby robbie.cee » Sun Feb 05, 2012 6:41 pm
"think" the vent will pop out with 2 small flat screwdrivers one either side of vent in edges. dont quote me on that tho if not try removing passenger dash top pod you can see stereo thru the holes :D
Had
MAKE IT FIT
robbie.cee
Postby IgorVigor » Wed Feb 15, 2012 4:21 pm
I forgot to update this :oops:
I wired the 2 power wires from the radio into the permanent live feed, so it now works without the ignition on :D
I did it when I had the dash apart to get the heater fan working :lol:
IgorVigor
Postby Altransit » Wed Feb 15, 2012 4:36 pm
I did something similar years ago on a van, I had a seperate toggle switch on the dash, so that I could override the ignition feed 8)
With the switch in one position, it worked normally, switching off when the engine was stopped, and in the other, the radio would work when the engine was off :wink:
I did it that way because on a couple of occasions, I left the van with the radio on, because I had turned it down and not off :oops: :P
Postby IgorVigor » Wed Feb 15, 2012 4:52 pm
my radio is a Kenwood, which glows blue when its switched on (even in the 'standby' mode), so its quite noticeable :lol:
IgorVigor
Postby robbie.cee » Wed Feb 15, 2012 8:45 pm
IgorVigor wrote:my radio is a Kenwood, which glows blue when its switched on (even in the 'standby' mode), so its quite noticeable :lol:
quite nickable too m8 ffs dont leave the face under seat/in van!!!! :wink:
Had
MAKE IT FIT
robbie.cee
Postby IgorVigor » Thu Feb 16, 2012 1:20 pm
I live in the countryside, so thefts like that aren't common 8)
I have to admit, I tend to leave the face on it most of the time :oops:
IgorVigor
Postby robbie.cee » Thu Feb 16, 2012 6:04 pm
Tisk tisk. only takes an opportunist thieving w*** to see it and pop your window for it, just to sell on again for £20/drugs :twisted:
All the damage they cause more like in the hundreds...fkn b*stards!
Rant over :D
Had
MAKE IT FIT
robbie.cee
Postby landiman » Thu Feb 16, 2012 8:31 pm
I know all about thieving little b*****ds... broke into my van by punching rear door locks in, stole two socket sets. now got heavy duty security lock fitted.... if i ever find out who it was......... :evil:
landiman
Postby trigger » Thu Feb 16, 2012 10:14 pm
landiman wrote:I know all about thieving little b*****ds... broke into my van by punching rear door locks in, stole two socket sets. now got heavy duty security lock fitted.... if i ever find out who it was......... :evil:
Probably Whitney Houston :lol: :lol: :lol:
Mk5 Transit the daddy
trigger
Postby btvanowner » Fri Feb 17, 2012 12:48 am
:lol: :lol: :lol: :lol: :lol:
ACCIDENTS ARE NOT FUNNY UNLESS ITS SOMEONE ELSE.....THEN ITS HILARIOUS
btvanowner
cron
