side light
side light
Postby SLANTEYEUK » Sun Feb 05, 2012 3:26 pm
hey guys, have a problem with front side lights, holder that holds the bulb in has smashed and ever since has been blowing fuses? can i buy a replacment holder rather than a full headlight? its a 54 plate. cheers jimmy
SLANTEYEUK
Re: side light
Postby robbie.cee » Sun Feb 05, 2012 9:26 pm
the wires inside are touching then m8 or earthing out on van. is it the side indicators or the small bulbs in headlamps? can get replacement holders pretty standard on many cars/vans! scrappy yard hunting time! :wink:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Re: side light
Postby SLANTEYEUK » Mon Feb 06, 2012 7:48 pm
its the small bulb inside the headlight mate, is there a part no to order 1? thanks for the help :mrgreen:
SLANTEYEUK
Re: side light
Postby fortyeight » Mon Feb 06, 2012 8:25 pm
look on ebay
fortyeight
Re: side light
Postby SLANTEYEUK » Tue Feb 07, 2012 5:39 pm
looked mate but cant find it, searching transit connect bulb holder and only the back holder comes up thats why i though them maybe a part number may help,cheers
SLANTEYEUK
Re: side light
Postby fortyeight » Tue Feb 07, 2012 7:09 pm
hi ive looked on ebay cant find any,maybe if you went to a car acceserary shop maybe they could get you one,if not a main ford dealer ,or take your old one to a breakers yard and get one or one that can make do
fortyeight
Re: side light
Postby robbie.cee » Tue Feb 07, 2012 9:24 pm
they are virtually identical to the ones found in your side repeater lights poss but longer- go check passenger side as easier to get to dont need to move the fkin battery!
Had
MAKE IT FIT
robbie.cee
