marchyboy wrote: Was informed by an independant clutch and gearbox specialist that the other possible scenierio was that when they removed the gearbox to replace the clutch they should have blocked a hole to stop oil leaking out maybe they didnt and so when they started it later there was no oil in the tensioner for the hydralic to work so when i picked the transit up it had already jumped a tooth on the camshaft thats why it was running so roughly, he also told me that it will be a high possibiity that valves and pistons will also be knackered,and advised me even if they get it running it will only last about 3 months and the crank will be the next thing to go as he said the mk7 is a great engine but made of plastic his advised me to get another engine.
