Whats your MPG ?????
Postby Luke » Sat Nov 11, 2006 7:13 pm
Post here the MPG of your van :!:
What you need to do if fill your van to the top drive around then refill to the top again then use THIS to calculate the MPG :D
also include any relevent details ie. body type, engine size type of driving and if you think your speedo is accurate :lol:
hopefully we should build up an idea of what mpg to expect from what van :!:
Do not post questions or related topics in this thread, they will be removed - this thread is just for the MPG your van has done :!:
Postby Guy88 » Sat Nov 11, 2006 7:16 pm
I got 18mpg from my MK3 SWB lo roof 2.0 pinto webber single choke. driving it around town :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat Nov 11, 2006 7:17 pm
right, mine :D
filled up - 46.69 litres having done 424.4 miles :D
mostly local runs but included some long motorway drives, works out to be 41.3 MPG :D
now even taking off the 10% for the speedo's inaccuracy (it does read high) its 37.2 :D which isnt bad at all :D
Van is a SWB low roof 100 1994 70ps Di and the rear axle is a 4.56 and 90% of that the van was empty :D
Postby ovlov » Sat Nov 11, 2006 7:45 pm
My MK4 pickup (on the left) seems to average about 34 mpg with various loads on it, It's never realy fully loaded though and I dont realy hammer it max is about 60 :roll: :wink: Its just a standard bannana engine
I want to live forever so far so good
ovlov
Postby gardener68 » Sat Nov 11, 2006 8:40 pm
1989 190 hightop 2.5diesel.kitted out camper/work van weight 2.34tonnes 27mpg average over loadsa miles/varied driving.
1998 150 coachbuilt camper.2.5turbo diesel.weight 2.5tonnes.22mpg wanting to get there. :twisted: 28mpg driving like grandpa :roll:
kicked the hightops ass in a race though :D
gardener68
Postby MarkM » Sun Nov 12, 2006 5:12 am
Mark 5 SWB120 2.5DI 70PS Low roof.
I get varying milage depending on how heavy my right foot is but between 425-460 miles per tank which works out to 32-34mpg. Half to 3/4 weight loaded, one day I will actually get a proper figure for the weight I am carrying but for now that is a guess. I honestly don't know if the speedo is accurate or not but gauging how all the cars around me seem to always match my speed at the fixed camera spots, I would say it probably is...that or everyones speedos are reading wrong.
*edit* Now got a sat nav and my speedo is reading approximately 2-3 miles per hour faster than indictated, which is I think makes my speedo pretty accurate all things considered when I see some of the figures quoted on here about the differences when compared with a sat nav.
I will add in my axle ratio when I find the code listings again..I know it is a 4. something
MarkM
Postby mrgasoil » Wed Nov 15, 2006 10:19 pm
99 Mk5 2.5DI flareside. My mpg is all over the shop, ALWAYS carrying summat(200kg of tail-lift) :shock: Easy 30+ empty, 25ish with a couple of barrels of gas on but if ive got 5 on(which puts me 40-50kg overweight) 8) i get 15-20 :cry:
mk5 flareside with tail-lift GONE and will be missed!
Mk6 T350 LWB DRW dropside with tail-lift.
mrgasoil
Postby madmark » Thu Nov 16, 2006 5:02 am
transit 280 125ps running around 155ps around town and genral driveing about 32mpg! :)
Postby jay » Thu Nov 16, 2006 1:11 pm
My swb turbo diesal was about 23-26mpg but thats local and a lot of stop start work as its been used for local servicing and repairs of local vehicles.
on a run to birmingham last month it did 36mpg
my luton turbo diesal did about 21-24 mpg but that was fully loaded and pulling a loaded trailer mainly on duel carrageways from ipswich to london 3 days a week..
jay
Postby Wolfie » Thu Nov 16, 2006 2:17 pm
worst 16mpg best 24mpg
2l V4 coachbuilt brick
1979 2L pinto camper
Wolfie
Postby frank_sumner » Sat Nov 18, 2006 4:08 pm
1996 2.0 Petrol Torneo.
Average over 15,000 miles is 27mpg.
Motorway cruising at 65-70mph = 30mpg.
Motorway cruising at 70-75 mph = 26 mpg.
Over 75 mph drops to about 23mpg.
Round town between 20-24mpg.
frank_sumner
Postby Trev » Sat Nov 18, 2006 9:46 pm
Pleased to see others getting similar mileages; I've an old but good double wheel high-top, kitted as a camper/work van about 2.5 tonne. 4.63 axle. Currently has a 2.5DI turbo with a *mechanical* fuel pump adjusted to get through a sympathetic MOT. I have to drive very light footed to get near 30mpg; average 25-27. On previous banana engine, I towed a 1.6 petrol astra on a car trailer across the country and got better mileage than I'd have got from the astra - about 34 - but at 50mph.
With a little adjustment to the fuel pump, same engine tows itself and 2 tonnes trailers up never ending spanish 5% autovia hills at constant 50 mph. Needs two electric fans to keep it from going out the other end of the red though! Overall fuel consumption on such very long journeys about the same!
Trev
Trev
Postby Gromit » Mon Nov 20, 2006 11:17 am
Just done a couple of long runs to Aberdeen (650miles round trip) and back and at a steady 65mph I got 34mpg.
Oh SWB 2.5Di non-turdo Smiley.
Is that :D or :( .
Cut, grind, weld, cut, grind, weld........just another day in the life of a Smiley owner.
Gromit
MPG
Postby mickreeves » Wed Nov 22, 2006 10:08 am
My 1989 2.5Di did 30 mpg, and we sometimes managed over 100 mph.
My 1992 2litre OHC petrol did 22mpg, then fitted simple LPG conversion and got 16 mpg. [equivalant to 32 mpg, gas is half the price of petrol]
I once got this up to 110 mph downhill.
My 1996 lwb 2 OHC efi did 22mpg on petrol, then eqivalent 33 mpg on lpg.
I used to drive fast. 80-90mph or more on motorways, foot hard down.
Then I got pinched doing 59 mph [checked on my satnav] in 60 limit.
I visited the police camera unit and was told that all vans and larger MPVs are limited to 50 mph on single carriageways, 60 on dual, 70 on motorway.
I started to drive within speed limits. The MPG was then 25 on petrol, 40 equiv on LPG,
I could not get a deffinative answer to exactlywhich vans came in this limit, but I changed my lwb bus for a swb ,9 seat Torneo with same DOHC petrol engine.
I fitted the latest sequencial lpg system. [£900 DIY]
Now get 26 mpg petrol, equiv 40 mpg on gas.
It should pay for itself in 10,000 miles.
As good as any deisal transit??
Mick
mickreeves
Postby Guy88 » Wed Nov 22, 2006 9:59 pm
i got 23mpg fronm my 70ps mk5 turned up 1.5 turnes on the pump. and using all the power it had :shock:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Return to Transit Talk
