LEGAL or not :(
LEGAL or not :(
Postby yttam84 » Tue Mar 20, 2012 9:43 pm
Not going to use them like this but then thought I might hide a button in case needed for any reason ??
yttam84
Re: LEGAL or not :(
Postby electric » Tue Mar 20, 2012 10:33 pm
If your using them as day running lights then they are probably to close to the centre of the vehicle, I don't think you'll have any problems though. :)
2005 T220 LX TDCi Rolling on 18 inch Jaguar alloys
http://www.acornautoservices.co.uk
Servicing and Repairs, MOT testing, A/C systems regassed
electric
Re: LEGAL or not :(
Postby Mylee » Tue Mar 20, 2012 10:53 pm
You can buy a DRL relay on the Bay which will control them correctly. On with ignition off with headlights.
Mylee
Re: LEGAL or not :(
Postby Stavros » Wed Mar 21, 2012 1:27 am
If you need help with connecting correctly can send you connection project where they will work with ignition and will be off when you swicht on position lights.
Also shuld be not lower than 20cm from the road and minimum 80cm distance between them (that european law in countries where you need to drive the all day) but im not sure if its same in the UK as we dont need drive on the lights all day :wink:
Ebay relay is about 15-20paunds and you can do this your self for 1 paund or free if you have any no needed 2 position 12v relay.
Stavros
Wrong Again!
Re: LEGAL or not :(
Postby get connected » Wed Mar 21, 2012 8:44 am
The ideal relay for the control of these lights is a split charge relay, as used on towbars for charging caravan batteries and powering the fridge when towing... The voltage sensing ones are best and a doddle to fit, they switch off at about 12.5v and switch on when the alternator is pumping....
Available from most good Motor Factors.
p.s The lights look good by the way :wink:
What about trying them above the bumper next to the headlights?
Keep a smile on your face at all times! The others think you know something that they don't !!!
get connected
Re: LEGAL or not :(
Postby yttam84 » Wed Mar 21, 2012 9:23 pm
did try that but they have a bracket on the top and it gets in the way a little ( well a lot in face ) I have 8 in total 4 white and 4 orange as there so cheap on the bay and was going to put the two orange ones in the grill and then two on the back right at the top of the doors as for wiring is not problem as I have a few ideas for how to have things and having a breakers just around there corner I have endless relays and so on lol I will post another video when there all in and working
I am a LED freak so u all know lol any were there’s a space there’s an LED :lol:
If I can find a picture of my old escort all will be explained :lol:
yttam84
Re: LEGAL or not :(
Postby Mylee » Wed Mar 21, 2012 10:58 pm
Why don't you go for strobes and fit them in the original lights, much neater.
Mylee
Re: LEGAL or not :(
Postby yttam84 » Wed Mar 21, 2012 11:48 pm
whats the idea of them ?? to look chavy been there done that :lol:
yttam84
Re: LEGAL or not :(
Postby Mylee » Thu Mar 22, 2012 12:16 am
yttam84 wrote:whats the idea of them ?? to look chavy been there done that :lol:
Not at all. It saves bolting lights everywhere and making your connect look like a ripspeed christmas tree.
Mylee
Re: LEGAL or not :(
Postby tez » Thu Mar 22, 2012 1:34 pm
well i got them on front off my van never be stop and told to take them off like :D
tez
Re: LEGAL or not :(
Postby mike-dyson » Tue Nov 20, 2012 8:55 pm
Old post but it save making a new one.
I'm wanting to put some day running lights on my van and have then on a switch in the shelf bit under the steering wheel.
Just a few questions...
Were would be a good place to get power from?
Is there any easy access from the cabin to the engine bay to run my cable?
Any help would be great thanks :D
mike-dyson
Re: LEGAL or not :(
Postby paul2012 » Tue Nov 20, 2012 9:21 pm
mike-dyson wrote:Old post but it save making a new one.
You could take a 12V+ live feed from the Engine bay Fuse Box from Fuse F22 or direct from Battery & run through a relay & Connect the relay switch wire to pin 4 (GN/YE) on the Headlight switch plug. This way the DRL will come on with ignition is switch on & switched off when headlights are turned on.
They do not have to turn off when headlights are turn on :wink: I have factory DRL on my 2012 Vauxhall Insignia & they stay on even when headlamps are on (Athough headlamps turns on automatically)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: LEGAL or not :(
Postby Mike » Tue Nov 20, 2012 9:24 pm
They should dim if they're taking the place of the parking/side lights, if they're separate from the parking/side lights then they can turn off or dim.
Mike
Wind up merchant!
Re: LEGAL or not :(
Postby get connected » Tue Nov 20, 2012 9:48 pm
Nice log burner/////////////////// :wink:
get connected
Re: LEGAL or not :(
Postby mike-dyson » Tue Nov 20, 2012 10:09 pm
paul2012 wrote:You could take a 12V+ live feed from the Engine bay Fuse Box from Fuse F22 or direct from Battery & run through a relay & Connect the relay switch wire to pin 4 (GN/YE) on the Headlight switch plug. This way the DRL will come on with ignition is switch on & switched off when headlights are turned on.
Ok, erm... so is that like a normaly closed relay then?
So you turn your iggnition on and the relay is closed so it lets power through to the DRLs, then when you switch the lights on it will pull the contactor out turning the DRLs off?
Were could i get one of these relays from?
And how do i get cables to the head light switch?
cheers for the help
mike-dyson
