280 / 06 / LPG/ Problem.
Re: 280 / 06 / LPG/ Problem.
Postby Rowdey » Sat Mar 17, 2012 3:32 pm
CROSSFIREROB wrote:Latest for anyone remotely interested or who may be having similar LPG issues ,i decided to remove the relay switch from the petrol side of things when the van turns over to gas ,and when this is done the van runs perfect , it doesnt cut out on idle ,when i put the relay back in she messes about again......anyone got any ideas :?:
Although i don't have many answers for you, i have this thread bookmarked and any new post alerts me, so always keep upto date with goings on - Keep posting, as i'm sure i'm not alone in this and keen to get more answers/info.
So you disconnected the relay, and it runs fine on LPG ? New relay then surely ?!
03 Dual Fuel MR MWB and now 66 Mk8 L2H2..
Rowdey
Postby CROSSFIREROB » Sun Mar 18, 2012 10:09 pm
I lied,it transpires that my Transit still wont sit on idle while running on LPG, ive had this van a year now, and this problem is very annoying , looks like im am going to have to give in and spend to much money at an LPG specialist, i really do throw the towl in now .Apart from the idle , the van works fine , although very slow and under powered, it does go alright but not exactly quick, and if i get to a hill im down to 45 sometimes on the motoway, the fastest it goes is 85 mph. :roll:
Rockin and a rollin all day long !
CROSSFIREROB
Postby M4tty » Sun Mar 18, 2012 10:14 pm
How many miles do you get from a full tank of petrol crossfire rob? I get about 300 :(
2005 Transit 260 SWB 2.3l 16V DOHC Petrol/LPG
M4tty
Postby mealic » Sun Mar 18, 2012 10:29 pm
CROSSFIREROB wrote:I lied,it transpires that my Transit still wont sit on idle while running on LPG, ive had this van a year now, and this problem is very annoying , looks like im am going to have to give in and spend to much money at an LPG specialist, i really do throw the towl in now .Apart from the idle , the van works fine , although very slow and under powered, it does go alright but not exactly quick, and if i get to a hill im down to 45 sometimes on the motoway, the fastest it goes is 85 mph. :roll:
Hi Mate,did you clean everything out...................distributor ?change plugs.Step up relays,check fuses in dash,change RPM filter ,clean MAF sensor etc etc.I know we have spoken before,but I am not going back through all the LPG posts.If I havn`t sent you all the info that I have,I can but it takes me time and money to print it all out,so I now charge £20.00 to send it all out,just to cover costs.Quite a lot of info there though.
`04 2.3 petrol/LPG
mealic
Postby CROSSFIREROB » Tue Mar 20, 2012 10:53 pm
Couldnt tell you the miles per tank on petrol Matty, but does 225 on £50 gas , i dont know what that equates to .
I havnt clened any parts, just wasted money on a new rpm filter is all, the van runs great with no problems until i either slow down or stop, and even then its not all the time ,the rpm will flutuate and then steady off or die, the other small problem is thats it doesnt seem to switch back to petrol very well, i have to hold the switch down for over 3 minutes before the petrol stays on constant , this is to avoid cutting out at junctions in town .
CROSSFIREROB
Postby Donkey-Boy » Sun Apr 01, 2012 10:37 pm
hi,
im new so be patient! snooping through posts gathering info to go towards the buying of an lpg transit. ive read a few of your problems and i have found this info on a lpg discussion forum. it might be of some use or maybe you have already seen it.
thought id register and share the link as im a mechanic and understand the frustration of a persistent problem.
http://www.lpgforum.co.uk/viewtopic.php?f=28&t=9047
3rd post from the bottom by someone called Edward.
good luck
Dave
Donkey-Boy
Postby CROSSFIREROB » Mon Apr 02, 2012 9:35 pm
Came back from a 200 mile journey on lpg , cost £38 because i drove a 60mph instead of 70 . :D
But still cuts out at junctions , other times it works fine , i have no idea what it is . :(
CROSSFIREROB
Postby mealic » Mon Apr 02, 2012 10:07 pm
CROSSFIREROB wrote:Came back from a 200 mile journey on lpg , cost £38 because i drove a 60mph instead of 70 . :D
Stepper motor needs cleaning properly or replacing.Has it been put back together properly?
Ali
`04 2.3 petrol/LPG
mealic
Postby CROSSFIREROB » Tue Apr 03, 2012 6:03 pm
The van hasnt had any cleaning of parts ,i very reluctant to start taking things off, simply because the van performs without fault except when slowing down to stop, the rpm gets confused, it almost stops then hessitates, sometimes it sorts itself out and ticks over nice , but on the hole it just cuts out , the LPG firms wont give any adice , they just want me to bring it in and pay £135 for a diagnostic check.
PS I PUT A NEW RPM FILTER in and it still does the same , i think i could have been sold a faulty RPM filter , butthst doubtfull.
Do you think i should strip the stepper motor down .
CROSSFIREROB
Postby mealic » Tue Apr 03, 2012 9:56 pm
Yes I think that you should clean the stepper motor.Have you ever changed the filters or cleaned the MAF unit.
`04 2.3 petrol/LPG
mealic
Postby CROSSFIREROB » Wed Apr 04, 2012 9:44 pm
No i havnt changed filters simply because it runs fine as it is , which makes me think the filters must be fine , but if you think i should do the tasks you mention i will take your advise and do it over the weekend, would you be kind enough to post a link to the parts i should by , i have the factory fitted necam lpg system on a 05 mk6 , thanks .
CROSSFIREROB
Postby mealic » Wed Apr 04, 2012 11:03 pm
CROSSFIREROB wrote:No i havnt changed filters simply because it runs fine as it is , which makes me think the filters must be fine , but if you think i should do the tasks you mention i will take your advise and do it over the weekend, would you be kind enough to post a link to the parts i should by , i have the factory fitted necam lpg system on a 05 mk6 , thanks .
:? :? If it`s running fine as it is,why post that it cuts out at low revs etc That`s not "running fine "to me!!Just try cleaning the components first ie the stepper motor.Really you need to replace the o`rings inside but you won`t get them before the weekend.There are already plenty of links stating where to obtain parts from.
`04 2.3 petrol/LPG
mealic
Postby CROSSFIREROB » Thu Apr 05, 2012 10:24 pm
Sorry if i was confusing issues, what i meant by running fine was that appart from the idle the van runs absolutely perfect all the time on lpg, but it often cuts out when i slow down and stop,but not all the time ,very often i will idle fine to ,thanks for the advice.
CROSSFIREROB
Postby CROSSFIREROB » Sat Apr 07, 2012 9:43 pm
IS the stepper motor the same as the IDLE SPEED CONTROL VALVE ,ive been reading and wasting hours about this , and after all of that it might just be this little blighter , i am going get it off tommorow and see what happens.
CROSSFIREROB
Postby CROSSFIREROB » Sun Apr 08, 2012 6:49 pm
I took it off and cleaned it , and the van still cuts out sometimes at junctions etc, i find the problem is not having any form of diagram as to where parts to the lpg are on the van ,for example where is the stepper motor lol, having lpg is a real head ache when it goes wrong.
CROSSFIREROB
