Bog standard Transit connect - NOT FOR LONG.
Re: Bog standard Transit connect - NOT FOR LONG.
Postby tazzys_transit » Thu Apr 05, 2012 11:14 am
that would be super
cheers
tazzys_transit
Postby connect_4 » Thu Apr 05, 2012 2:08 pm
Part number is :
7T16-V04302
http://pbckt.com/pO.RWAFzM
Click on the link above fir a photo of the back of it showing the part number.
connect_4
Postby connect_4 » Thu Apr 05, 2012 3:10 pm
connect_4
Postby tazzys_transit » Thu Apr 05, 2012 3:28 pm
thanks mate going to order myself one tomorow
cheers
tazzys_transit
Postby connect_4 » Fri Apr 06, 2012 12:45 pm
I went to B&Q today and asked for Fablon, they have a rack of it by the wallpaper section.
I got a roll of Black for £7.58.
So i measured and cut out a section, it has a very helpful grid printed on the back of the backing paper to help you cut in straight lines.
I fitted it to my van, used an 11" deep piece to cover the centre dimpled dot section in the middle of the windscreen.
This is how i did it....
I cut a piece from the roll measuring 142cms long and 30cms deep and then offered this up to the windscreen.
Then i used masking tape to hold the strip in place and measures to make sure it was level.
I then cut the strip to shape around the top of windscreen using a stanley blade.
Then i sprayed the windscreen with soapy water, peeled off the backing paper and applied the strip to the windscreen.
You can then move the strip around because the soapy water prevents it from sticking to the windscreen.
Once i was happy with the correct positioh i used a plastic credit card type thingy to push out all of the bubbles and the excess water from under the strip.
Simples.
I also bough an LED display for the back on the van, when i have the dogs on board i drive a bit differently, i drive slower, take corners gentler etc etc, but because of this i always get some bell end up my chuff giving me the road rage, so i got a sign to explain....
http://www.youtube.com/watch?v=hBSFdu_B1-w
connect_4
Postby Drizz » Fri Apr 06, 2012 7:36 pm
How much was the led bar?
Drizz
Postby connect_4 » Fri Apr 06, 2012 8:54 pm
Drizz wrote:How much was the led bar?
£25 delivered from ebay.
http://www.ebay.co.uk/itm/CAR-ADVERTISI ... 3393wt_989
connect_4
Postby bigjohnthomas » Fri Apr 06, 2012 11:26 pm
:lol: :lol: :lol:
8) 8) 8)
bigjohnthomas
Postby tazzys_transit » Wed Apr 18, 2012 3:22 pm
hi mate
its me again
if got a final qeustion for you
about the heatercontrol knobs
got myself the whole midconsole for the 2din
but the heaterknob ist this only a new knob or a whole new unit ? maybe a partnumber by any chance ?
i know i ask alot butt hope you can an will help me once more
thanks in advance
greetz kevin
tazzys_transit
Postby tazzys_transit » Sat Apr 21, 2012 10:45 pm
never mind mate had one helpfull ford dealer over here he screwed the console out of a van they had for sale to take a look
thanks anyway you helped me a lot
grtz tazzy
tazzys_transit
Postby Drizz » Mon Jun 18, 2012 9:44 pm
Any more updates? Also what front springs are you on? Mk1 rs standard heights or mk2 focus?
Drizz
