280 / 06 / LPG/ Problem.
Re: 280 / 06 / LPG/ Problem.
Postby mealic » Sun Apr 08, 2012 7:18 pm
CROSSFIREROB wrote:I took it off and cleaned it , and the van still cuts out sometimes at junctions etc, i find the problem is not having any form of diagram as to where parts to the lpg are on the van ,for example where is the stepper motor lol, having lpg is a real head ache when it goes wrong.
Mate,I thought that I had sent you every diagram and procedures for servicing and cleaning that I have ages ago.I`ve started charging £12 for the whole package .because I got so many requests I kept running out of ink on the printer.It`s like a serviice guide.You must be one of the few that hasn`t benefitted from it all.If you like I will pop a load in the post tomorrow and you can Paypal or whatever,whenever.WDYT
`04 2.3 petrol/LPG
mealic
Postby CROSSFIREROB » Sun Apr 08, 2012 8:48 pm
HI i have sent you a personal message via this forum, thanks .
This situation is annoying , i dont mind taking the van in to a lpg specialist , but at the same time i dont want to be taken for a ride, they may find its somthing simple but drag it out so as to earn an extra buck ,i trust noone these days .
Rockin and a rollin all day long !
CROSSFIREROB
Postby CROSSFIREROB » Mon Apr 09, 2012 10:20 pm
Today i took off the LPG stepper motor and cleaned what i could , and it made no difference . :mrgreen: ,and i knew it wouldnt :mrgreen:
CROSSFIREROB
Postby steve the fitter » Fri Jun 01, 2012 11:23 pm
anyone ever have any luck resolving this problem? Been reading posts all night about people with petrol lpg transits where the petrol works fine but it misfire, cuts out etc on the lpg front. Not one of the pts have had any positive outcome so be good to hear from anyone who has managed to fix the problem.
Im thinking of trying these spark plugs out
http://www.ebay.co.uk/itm/4x-DOR15LGS-G ... 2934wt_979
Seems a lot of people think its a the rpm filter but when they change it it makes no difference
steve the fitter
Postby M4tty » Sat Jun 02, 2012 11:13 am
I have contacted a guy called Edward from the lpg forum who is coming down soon to hopefully sort it out. He hasent been beaten yet so hopefully mine will be sorted soon. Will report back once he's been down :)
2005 Transit 260 SWB 2.3l 16V DOHC Petrol/LPG
M4tty
Postby loot » Sat Jun 02, 2012 11:18 am
I know how lpg works but have not worked on any, do Ford do a factory lpg van or is it always aftermarket? If Ford do sell an lpg van then surely they would specify which plugs to use? If this is the case then wouldn't fitting the plugs tell you if the problem is with the lpg system or otherwise? I'm only asking this as i have seen another thread covering the same subject :?:
07 350 170ps
Ids map here
loot
Postby M4tty » Sat Jun 02, 2012 11:24 am
They are factory fitted mate but you can't get an official manual for them. Bit of a nightmare :)
M4tty
Postby steve the fitter » Sun Jun 03, 2012 9:16 am
been looking into this quite a bit the last few days and starting to think it could be a blocked distributor. Ive always felt that something is getting blocked or the gas isnt getting thru for the van kangaroo along before switching back to petrol.
I hear you can clean some little slits on the distributor which allow air flow into it but I dont even know where the Koltec distributor is? Can anyone point me in the right direction please?
Also I have bought an engine cleaning product and a cat converter cleaner hoping they may make a bit of difference. I will keep you all informed how it plans out as i have read so many post recently which just finish without any answers. .
Anyone fitted the Brisk silver plated spark plugs? Are they a gimmick or a good buy?
By the way my van is a 330 SWB Transit 2002 but thought Id post on this as I imagine the lpg side is pretty much the same
steve the fitter
Postby steve the fitter » Sun Jun 10, 2012 8:44 pm
Lets not let this thread die a death like the rest of the lpg threads
Did you get Edward round Matty? Did he manage to solve the problem and if so what was it in the end?
steve the fitter
Postby CROSSFIREROB » Mon Jun 11, 2012 7:23 pm
My problem is now fixed, and i have kicked my own teeth in several times since , now for those who have the lpg system, this is for you , when someone tells you to clean out the stepper motor , dont do what i did , i took the top off and didnt see anything else so cleaned what i had and put it back on , so i in fact cleaned f*** all, which is why it made no difference , when you take of the top of the stepper motor look out for small ball bearing sitting on the rim , then reach inside of the cylinder and pull out the cup which is the bit you want to clean that i never saw, it has o rings on the out side, take them off , clean the plastic part with spray cleaner, then put the o rings back on , then here comes the bit i wouldnt have done due to not knowing , you must spray the thing with silicone spray so it relocates without rubbing the o rings off, then put it back together and bobs your uncle you will have a good working van, this should take about 30 minutes , and will not cost you £125 that it cost me,on that note dont go to Arun Gas unless you really have to , the mechanic is a real good knowledgeable ,guy but the boss is a money orientated prick, if you have any problems after you have been to them , he will just tell you to book in again as he did with me,my van was stuttering a bit , so i rang him and he had no advice other than booking it in , total idiot, done himself no favors there .
CROSSFIREROB
Postby Rowdey » Mon Jun 11, 2012 8:07 pm
steve the fitter wrote:Lets not let this thread die a death like the rest of the lpg threads
He's coming to see both of us ( in South London) next week. All the way from Shropshire no less..
Will update when we know more. :)
03 Dual Fuel MR MWB and now 66 Mk8 L2H2..
Rowdey
Postby Rowdey » Mon Jun 11, 2012 8:08 pm
CROSSFIREROB wrote:My problem is now fixed, and i have kicked my own teeth in several times since , now for those who have the lpg system, this is for you , when someone tells you to clean out the stepper motor , dont do what i did , i took the top off and didnt see anything else so cleaned what i had and put it back on , so i in fact cleaned f*** all, which is why it made no difference , when you take of the top of the stepper motor look out for small ball bearing sitting on the rim , then reach inside of the cylinder and pull out the cup which is the bit you want to clean that i never saw, it has o rings on the out side, take them off , clean the plastic part with spray cleaner, then put the o rings back on , then here comes the bit i wouldnt have done due to not knowing , you must spray the thing with silicone spray so it relocates without rubbing the o rings off, then put it back together and bobs your uncle you will have a good working van, this should take about 30 minutes , and will not cost you £125 that it cost me,on that note dont go to Arun Gas unless you really have to , the mechanic is a real good knowledgeable ,guy but the boss is a money orientated prick, if you have any problems after you have been to them , he will just tell you to book in again as he did with me,my van was stuttering a bit , so i rang him and he had no advice other than booking it in , total idiot, done himself no favors there .
Good to hear your sorted - it's been eventful..!
Rowdey
Postby axevalleycouriers » Tue Jun 12, 2012 2:38 am
Hi to y'all. Just discovered this forum and thread.Some really helpful stuff here.
I have the 2006 260 swb lpg transit. Have had it 2 months and experienced some of the same problems with vibrations thru gear stick on lpg and runs best at high revs, but is better on petrol.
Could the guy who has info packs for £12 tell me how i can get 1 please?
Also can anyone reccommend a mechanic in the dorset/devon area who can help doing the necessary work, as I'm totally confused looking at engines after 1995!
Many thanks to those who have posted, tis sure to make my life easier as I improve my van!
Mat.(another one)
axevalleycouriers
Postby Rowdey » Tue Jun 12, 2012 11:49 pm
axevalleycouriers wrote:Hi to y'all. Just discovered this forum and thread.Some really helpful stuff here.
Mat.(another one)
Hi Mat, PM mealic at http://fordtransit.org/forum/memberlist.php?mode=viewprofile&u=2257
Rowdey
Postby steve the fitter » Sat Jun 16, 2012 8:34 pm
Great a couple more posts with a solutions to one vans problem.
I know nothing about cars or vans but have tried reading up on the lpg transits and have never heard of the stepper motor. Where abouts is it located pls?
Also Rowdey. How did it go with Edward?
steve the fitter
