MK6 SWB Cosworth YB Conversion!
Re: MK6 SWB Cosworth YB Conversion!
Postby Luke » Fri May 25, 2012 8:57 pm
had some good progress on this today 8) 8)
sorted the engine - it was the map sensor - we'd got a 2wd one and the wiring is different - it's now running standard so we can get it MOT'd
still got the problem with the green injectors - anyone any ideas why they didnt work :?:
also spent a bit of time sorting the pipework out that we rushed to get it done for NW08 got a few more bits to sort but it's looking good for NW12 :mrgreen:
and here's a pic with the new wheels and tyres fitted 235/50R18 commercials 8)
Postby Luke » Mon May 28, 2012 9:12 pm
fitted a new side loading door, back door and 2 new rear shockers today also piped the internal heater up :D we tested the new fan switch and it cuts on and off nicely - it's previously has the fan on a manual switch - nice to get these little jobs done on it to make it a usable van 8)
i drove it up and down the street for the 1st time in ages 8) the back axle is definatly an improvement from what i remember :!:
.................... MOT booked for thursday :D
Postby AlanN » Mon May 28, 2012 9:44 pm
good luck with the MOT :D
Postby Luke » Thu May 31, 2012 8:35 pm
MOT passed 8) 8) 8) 8) 8)
now just got to get it sorted for north weald 2012 at the moment the amil valve is broken and its stopping it boost right so stu's ordered one off ebay
fit 330bhp chip
fit green injectors (£60 to have the u/s ones we have repaired)
swap wiring for 2wd map senser and plug in (hope it works)
fit new amal valve (on order from ebay)
then we're all set :mrgreen:
Postby AlanN » Thu May 31, 2012 10:37 pm
Blimey, you are cracking on :D
Postby Luke » Thu May 31, 2012 11:21 pm
yeah being a spectator at NW last year was just too much :lol:
one more thing we'd like to do with this van is lower it 3-4" all round :idea:
Postby AlanN » Fri Jun 01, 2012 8:12 am
Mmmmm! yes, can you do mine too 8) :lol:
Postby Gurj51ngh » Fri Jun 01, 2012 10:07 pm
Luke wrote:yeah being a spectator at NW last year was just too much :lol:
Yep for sure!
Let me use the van for a year the suspension will be so abused by then you wont need to lower it!
Gurj51ngh
Forums Loudest Van!
Postby Luke » Sat Jun 02, 2012 8:34 pm
no problem gurj so long as it comes back with a half decent sterio fitted something similar to yours :lol: :lol:
spent a bit of time on this today, fitted the new (ebay 2nd hand) amil vakve on and it didnt work - put a voltage to it and it's u/s :x a bit annoying as it was supplied as tested working ok :roll:
we really wanted that working fine before we start messing with the ecu but we couldnt resist :lol: tried the chipped ecu - didnt work :( stu then remembered the chip wasnt actually fitted :lol: it was about 3 years ago we bought it :roll: fitted the chip and took it for a blast 25psi boost straight away 8) 8) as the rest of it isnt ready i put the standard one back on for now :)
unfortunatly we still couldnt get the MAP senser to work - i even swapped the wiring over and still no good :?
the ecu (chipped one) is a 2wd but the rest is 4x4 - is that a problem :?: anyone :)
the injectors have been sent off we're waiting for them to come back, and now we need another amil valve, but it's still worth taking to north weald as it is so it'll be there definatly now 8)
Postby Luke » Tue Jun 05, 2012 6:03 pm
stripped the 'new' amil valve and the pins just broke off it was badly corroded inside but the seller is sending another :D - so while we had a bit of spare time we fitted the origanal one with the intermittent fault and bent a pin over so it works ok for now - (we'll still bin this when the next one arrives) but now we've piped up the actuator we had a few runs up and down the road to get the boost set right we has 15psi and it kept cutting out so we reduced it gradually untill we had 10 psi and it still cut out (anyone know what it should be on a standard set up ??) anyway then gave up and tried the chipped ecu this didnt have a cut out on it so we wound the boost back up to 15psi :twisted:
now we're gonna stop playing and just drive it steady until we get the right injectors and map senser fitted :roll: dont want to cause any damage :? but it was a very interesting day learning and understanding how it works :)
we'd like to fit a 3 gauge pillar pod - anyone done this to a mk6 before :?: any tips :?:
we want to have an engine oil pressure, turbo boost and an air/fuel ratio gauge fitted! the a/f gauge so we can monitor how the engine is running :idea:
there's still so much more we can do to this van, i think the air filter is in a bad place, doesnt get much air flow and it gets a lot of heat off the turbo :| but it's getting to the point where it's nearly a usable van :lol:
Postby transitandy » Tue Jun 05, 2012 8:08 pm
I just dont know where you find the time luke with all that you have going on :!: :wink:
Postby KING OF ENGLAND » Tue Jun 05, 2012 8:13 pm
transitandy wrote:I just dont know where you find the time luke with all that you have going on :!: :wink:
In luke's words its easy (its not real work) :lol: :lol:
KING OF ENGLAND
Postby MinorMatt » Tue Jun 05, 2012 8:49 pm
you should be getting the other one ready really... ;)
Postby belly » Tue Jun 05, 2012 9:37 pm
Get on Passionford Luke :wink: Those boys have some seriously anal cossie knowledge 8) Nice work btw and a good choice of rubber 8)
belly
Kaiser Chief
Postby Luke » Tue Jun 05, 2012 10:16 pm
MinorMatt wrote:you should be getting the other one ready really... ;)
they will both be there matt :mrgreen: i've actually been doing both today but not really anything worth writing about on the other :? :D
i do like working on this van too - although its not my van it's nice to build something like this...... and at the end of the day there's still a certain nitroman that holds a record (15.99) that needs to be smashed :lol: :lol:
belly wrote:Get on Passionford Luke :wink: Those boys have some seriously anal cossie knowledge 8) Nice work btw and a good choice of rubber 8)
yeah i'm on passionfords thats where i found that the map sensor isnt different 4wd to 2wd like it said in the book i'd got :roll: :D
