mk5 transit glow plugs or not? ecu or not?
Postby jay » Tue Jun 19, 2012 3:08 pm
right had a little argument at work last night with someone well more banter really..
he says my mk5 must have glow plugs and electric injectors and a ecu which controls the engine and all electrics....prove him wrong peeps.
btw I know I am right as been on transits for years
pic of my van A swb semi high 2.5Di
oh keep it clean as I will be showing him this thread..
mk1 connect tourneo
jay
Re: mk5 transit glow plugs or not? ecu or not?
Postby Altransit » Tue Jun 19, 2012 3:22 pm
Ford Di engine .................. absolutely NO glow plugs, could have an ECU if it's a Turbo, but definitely NOT electronic injectors :P :D
Postby jay » Tue Jun 19, 2012 3:43 pm
My van is non turbo..
mk1 connect tourneo
jay
Postby Altransit » Tue Jun 19, 2012 3:45 pm
jay wrote:My van is non turbo..
Just pointing out the options ..... :wink:
Postby KevAmiga » Tue Jun 19, 2012 4:06 pm
Deffo no glow plugs.
2003 Renault Trafic 1.9DCi
KevAmiga
However... if there are no glow plugs, how does it start?
KevAmiga
Postby jay » Tue Jun 19, 2012 5:30 pm
2.5Di is direct injection
only indirect have glow plugs but newer direct injection have them to assist in cold start emmisions.
mk1 connect tourneo
jay
Postby ake » Tue Jun 19, 2012 5:55 pm
Transit 2.5 Di was never fitted with glow plugs, and should start at - 15 without assistance. The flame start option was fitted to 115ps turbos and some overseas versions.
The fuel system is a mechanical pump and injectors, and if you remove the plunger from the stop solenoid the engine will run without a battery or alternator.
The Di would start with out glow plugs because the compression ratio is so high, modern turbo diesels have a lower compression ratio, and so have glow plugs fitted to reduce emissions and help cold starts.
Postby trasitman » Thu Jun 21, 2012 7:36 pm
Just had this conversation just to find the answer to our questions posted only 2 days ago!¬!
trasitman
Return to Transit Talk
