****IMPORTANT**** transits being stolen ****Must Read****
Re: ****IMPORTANT**** transits being stolen ****Must Read***
Postby motorman116 » Thu Jul 12, 2012 9:39 pm
jls security wrote:Tracker system? This would recognise vehicle movement if moved without the engine running and you ( vehicle owner) gets a call from control room to let you know.
Surely a worthwhile investment??
What sort if price are these??????
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby martynx » Thu Jul 12, 2012 9:47 pm
I havent read all the thread pages guys so apologies if its already been covered - i'd guess the security is bypassed by via the obd socket, it certainly is on some VAG group vehicles.. you could easily extend the obd plugs wires & reroute it to a totally different part of the vehicle , only a few of the 16 pins are connected. or put the 2 CAN lines on a hidden simple connected/not connected switch.. :?:
martynx
Postby loot » Thu Jul 12, 2012 9:55 pm
You can make a 10 quid mobile call you when the van is pinched,a bit of soldering required and a 5 quid circuit from maplins, but easy enough,
I tried to patent the idea in 2002 but couldn't :cry:
07 350 170ps
Ids map here
loot
Postby TIMO » Thu Jul 12, 2012 9:58 pm
loot34 wrote:You can make a 10 quid mobile call you when the van is pinched,a bit of soldering required and a 5 quid circuit from maplins, but easy enough,
Speak up then fella... :?: curious .
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby 75psT330lwb » Thu Jul 12, 2012 10:11 pm
I thought these vans were getting pinched by driving them away :?: :? surely a tracker is of no use till u find its gone missing :?: does this affect mk7's only or mk6's aswell :?: :?: :?: getting very concerned about this especially when ive got a set of sportvan rims and kit going on sometime soon :!: :(
Custom Ecoblue
75psT330lwb
Postby loot » Thu Jul 12, 2012 10:12 pm
Ok 10 quid mobile phone from tesco, 5 quid timer/relay circuit from maplins(you build it up/solder components in)
You basically solder 2 wires to the make call contacts on the phone keypad which go to the circuit board that goes to the trigger and you also need to sort out a phone charger, then you call the mobile from your mobile and its set up so if the alarm goes off it calls
you!
I also had a dictaphone connected so i could record a voice something like ya car is being pinched but it isn't necessary,i just put rob in my contacts, obviously don't put car alarm as ppl may read that lol.
I used an early Vodafone mn1 phone for the job.
It did work a treat but you would need to set it off once in a while to check it.
i was hoping some 1 would have a go so i could see the look on their face of astonishment
When i appeared.
:wink:
07 350 170ps
Ids map here
loot
Postby TIMO » Thu Jul 12, 2012 10:30 pm
Superb pal,,, think ya could throw me a bomb together :?: :shock:
TIMO
Postby Mike » Thu Jul 12, 2012 10:51 pm
75psT330lwb wrote:I thought these vans were getting pinched by driving them away :?: :? surely a tracker is of no use till u find its gone missing :?:
Tracker will phone you as soon as your vehicle moves without the tracker tag in it. Doesn't matter if the genuine keys or copies are used.
http://www.tracker.co.uk/b2c.html
Mike
Wind up merchant!
Postby loot » Fri Jul 13, 2012 12:06 am
There are trackers and alarms that can call you up, i know there was an alarm that had a pager incorporated at the time i was trying,.
Shortly after i gave up it was on tomorrows world in Japan and was supposedly going to be available on the new mini 1 but don't know what happened lol.
But hey for around 20 quid and some soldering skills ya can't go wrong!
:o
07 350 170ps
Ids map here
loot
Postby Surfunitone » Fri Jul 13, 2012 6:33 am
My first converted camper was broken into in a car pack near the golf course in Newquay... I had retreated to the comfort of my bed after drinking too much beer in town. The person that broke in was not expecting me being asleep in the back, but woke just in time to bashing him with my bat! Missed his head but it must have hurt as he made a strange noise and yelp...
2.2 Duratorq-TDCi (110PS)
Surfunitone
Postby stusledge » Wed Oct 31, 2012 7:45 pm
My Mk7 transit was stolen last week, Slamlocks, loom covers, factory alarm & deadlocks, apparently there was seven taken in the area that week!
The police claim its easy, they clone the key.
Mine was taken off the drivers drive below an open window, no sound nothing so everyone beware!
stusledge
Postby Bulldog 73 » Tue Jan 29, 2013 3:21 pm
What you need is one of these line locks. you plum it in somewhere in the cab and undo the handle so you can lock it and take the handle away you. you press the footbrake to lock the wheels turn the lever brakes lock on so it has to be drag away and that make loads of noise
Mike
http://www.ebay.co.uk/itm/Brake-line-lo ... 4600945f60
Bulldog 73
Postby 75psT330lwb » Tue Jan 29, 2013 9:56 pm
take it your the one selling the linelocks then :roll:
Custom Ecoblue
75psT330lwb
Postby mealic » Tue Jan 29, 2013 11:36 pm
Try JJC Race and Rally, £5 cheaper at £26 and free postage =£12.50 cheaper for the similar product. :)
`04 2.3 petrol/LPG
mealic
Postby limitedblack » Tue Jan 29, 2013 11:45 pm
One major flaw in the alarm route is that the negative lead from the battery runs down the outside of the drivers seat, open door, cut lead, everything dead. Yet another bad design by ford. I have about an extra 2 miles of cable in mine, tracker, microwaves, tilt sensor, ultrasonics, ect. Plus it's locked away on a fenced hardstand, also cctv. Yet I await coming home to find it nicked:(
Happy Easter
limitedblack
