enjoythistripp wrote:I wasn't aware I could just fit a newer lump in, would i need to get the new lump certified?? I nned a new enging for the luton anyway, would 5k buy a decent newer engine
Hi mate, to meet with LEZ compliance, you can
NOT fit a newer diesel engine, but you
CAN fit
ANY petrol engine
Daft though it seams, the above is the case.
If you have a commercial vehicle that is fitted with a diesel engine and is not LEZ compliant, then you have two options;
Particulate filter, a LOT of money,
or;
Fit a petrol engine.
A point to note, a non commercial vehicle, such as a mini bus, fitted with a petrol engine WILL require a cat and therefore a fuel injected engine with all the associated electronic management system, and be subject to a cat test at MOT.
A commercial vehicle first registered before August 2002 does
NOT require a cat and can therefore be fitted with a carb engine, this simplifies installation a lot.
The simplest installation is the Pinto, as detailed in this thread, utilising our power steering pump bracket so as to retain the 2.5Di power steering setup and our engine mounting brackets if your vehicle is a Mk5.
Another option is using the 2.3/2.8 carb Granada engine, this can be fitted to the Mt75 gearbox using the 2.9 SVO adapter kit. These kits are rare and therefore expensive, the distributor is positioned at the rear of these engines, making access difficult in a Transit, we have not produced power steering brackets for these engines as yet.
The final Ford option is the 2.5/3.0 Essex V6, this is a great engine, easily and cheaply available, has a lot of low down torque making it ideally suited to a heavy vehicle such as a Transit and has the distributor at the front making access easy. We have developed a kit to install these engines in Transits onto the 2.5Di Mt75 gearbox and provide engine mountings and power steering pump fitting brackets.
Of course, any petrol engine could be fitted to achieve LEZ compliance, but in most cases, owners of the older non compliant Transits are on a limited budget, so the most cost effective solution is often what is required.
