What did you do to your connect today?
Re: What did you do to your connect today?
Postby Connect-rick » Thu Jul 19, 2012 10:29 pm
Thieves would have a wet dream if it were permanent! I use my iPhone tomtom and it's loads better than the shitty garmin I had
2006 white 75ps
EGR blank
Sony head unit, vibe slick 6x9 and ripspeed rs132 in front.
Connect-rick
Postby C8XY » Thu Jul 19, 2012 10:30 pm
Honey monster wrote:http://www.ebay.co.uk/itm/SWIVEL-AIR-VENT-CAR-KIT-MOUNT-HOLDER-FOR-APPLE-IPAD-2-/170667303845?pt=UK_iPad_Tablet_Accessories&hash=item27bc9063a5#ht_1877wt_1270
http://www.ebay.co.uk/itm/2-Tubes-Super ... 706wt_1270
Job done
I'm thinking super glue it to the massive visors!! Could whack a 15" monitor on them bad boys :D
C8XY
Postby GKandR4CH » Thu Jul 19, 2012 11:00 pm
I got a lovely diamond white passenger door to replace the door I currently have which had a dent beneath the door rub strip when I removed them.
£90.00 delivered.
Read the forum rules
GKandR4CH
Postby mike-dyson » Sat Jul 21, 2012 9:53 am
dieselboy1978 wrote:
mike-dyson wrote:Added passengers seat Mk3 Mondeo St220 Recaro and made a nice sticker for the plate seat bolted too.
what is it you have done here? is it a steal plate with the seat welded to it and and bolted into the van?
I'm looking at getting some better seats for mine and i think this could be the solution to fitting some.
No welding mate.
Taken standard seats out, Got some metal plate, about 1/4 inch thick, and picked up the existing bolt holes in chassis.
Then worked out where the seat sits best on the plates and drilled and tapped thread into plate.
Bolted seat onto plate. If need to put original seats back in then plates just come out and seats bolts back onto floor plan.
Used 12.9 or 14.9 high tensile bolts for bolting plates and seats in. No worries about bolts snapping or ripping from threads.
Then I just powder coated the plates to make the finish much better and put a green sticker saying CONNECT to finish it off.
Ahh cheers i think this is what i'm going to do :) just need to find some seats now.
mike-dyson
Postby westers » Sun Jul 22, 2012 10:12 pm
did a bit of work to the interior of the van today,
made a cardboard template of my bulk head,
cut it out and to size
masked up the speaker holes and top to stop glue flying everywhere :lol:
stuck it up :)
cut out the scribes
then fitted these back in and moved my amp ready for the new seats 8)
got some work to do on the bottem to hide the wires before i carpet that, but i think its looking pretty good :)
then put one of my seats in to see how to go about fitting them, still not decided how yet :lol:
WESTERS T220 LX connect
westers
Postby dieselboy1978 » Sun Jul 22, 2012 10:15 pm
Looks good mate.
Planning on painting mine white as mine is original metal one and not wooden one.
Bank account emptied by
DELPHI
dieselboy1978
Postby C8XY » Mon Jul 23, 2012 7:28 pm
Installed some reverse parking sensors. Nice and easy :)
C8XY
Postby SWtechnologies » Mon Jul 23, 2012 10:23 pm
so i got my rear disc conversion fitted today... still need to fit h/brake cable as motor factors i use couldn't get me one till tomorrow!
thanks to modyourtransit.com for helping to empty my bank account!!! :lol:
SW technologies
SWtechnologies
Postby westers » Mon Jul 23, 2012 10:34 pm
C8XY wrote:Installed some reverse parking sensors. Nice and easy :)
im tempted with reverse sensors :lol: just to make the van look more posh :P
westers
Postby C8XY » Mon Jul 23, 2012 10:43 pm
I'm trying to spec mine up, sensors not really needed but theyre a nice little feature :)
Also, cant go wrong for £12!!
C8XY
Postby westers » Mon Jul 23, 2012 11:06 pm
That was my thought not really needed but a nice additio! ( like most things :lol: )
westers
Postby rennie » Tue Jul 24, 2012 10:50 am
I wouldn't be without reversing sensors now and an early encounter proved just how good they are.
Selected reverse after looking through the mirrors and pulled back, but there was a beep so stopped and looking in the mirror saw a person who must have been right in the middle of the van at the time.
One point worth a mention is the sensor's for the connect.The Xvision one's I originally installed were flat one's and beeped far too often - due the downward angle after fitting to the bumper.
Do your's work OK as they look a flat too?
Corrected after by fitting Xvision angled one's which work perfect.
rennie
Postby Drizz » Tue Jul 24, 2012 1:49 pm
Ive got some for mine with the correct Ford positioning collars, so once the bumpers painted ill put them in!
Drizz
Postby mike-dyson » Tue Jul 24, 2012 7:08 pm
SWtechnologies wrote:so i got my rear disc conversion fitted today... still need to fit h/brake cable as motor factors i use couldn't get me one till tomorrow!
could you put a pic up of your van because its looks amazing on your profile pic :shock:
mike-dyson
Postby C8XY » Tue Jul 24, 2012 8:18 pm
rennie wrote:One point worth a mention is the sensor's for the connect.The Xvision one's I originally installed were flat one's and beeped far too often - due the downward angle after fitting to the bumper.
They are flat and beep quite often, I have the angled collars and will be installing tomorrow :) well spotted!
C8XY
