by belch » Sun Aug 19, 2012 2:32 pm
pretty new to this veg oil mullarky myself so hopefully looking forward to some insightful info regarding the mk5 with bosch.
my take on it is that there are 5 main groups that apply,
1: Bio diesel at the pumps, not seen any locally so not an option for me.
2: wvo ( waste veg oil ) cheaper if youv'e got a supplier but needs filtering etc & need to make sure no fats or water present. Gettin rid of the sludge after doesn't sound that pleasant either.
The svo's ( straight veg oil )
3: rapeseed oil -- seems to be the lightest of the veg oils so probably best suited for running all year with least thinning required, more expensive generally & i have read ( take with pinch of salt ) that it's slightly less efficient.
4: sunflower oil -- slightly thicker than rapeseed needs some thinning in colder months & reasonably priced ( especially when the missus works for tesco 89p/l at the mo )
5: soy based-- ktc brand seems to be the most commonly used & is the heavier of the 3 svo's mentioned , from what i've read it's fine for summer use but will need thinning in winter to avoid clogging up.
It appears to be a trial & error thing for working out what's best for each vehicle , some will work happily on 100% veg while a similar one struggles, presumably this is wear relating to indvidual engine components.
Start with a weaker veg oil to diesel mix & work your way up til the vehicle tells you it doesn't like it.
As for fuel filter changes , this depends on what crap the tank has in it before you start , the veg oil will carry more particles to the filter so a change after 2-3 hundred miles wouldn't be a bad place to start & it would give an idea of what's happening but be prepared & always carry a spare just in case.I believe there is also a coking issue with all the veg oil options with the soy being the worst so more frequent engine oil changes are required.
A 2 tank system would be nice Though that may be something for the future.
Mk5 1998 2.5di 76ps 80 swb vegetarian
