loot34 wrote:Right I'm in agreement with you, the bit I'm stuck at is if the egr is closed and the extra pressure isn't felt by the maf that's when the code comes up?
Does the extra back pressure in the exhaust cause problems for the turbo? Similarly to a blocked dpf?
Is there a sensor that monitors exhaust back pressure?
Will the lack of nox and egr operation cause engine wear at higher temps due to not having the cooling effect?
And would creating a variable output to the maf to make it think it is range and remove the warning lamp?
Also the egr pcm operates the loop system? Would linking the output of the motor to the variable resistor that monitors the egr valve position to the maf input(indirectly) cause a feedback?(what I'm asking here is if we were to use the motor to control the egr pos sensor, then modify an output that is accepted by the maf within tolerable levels would the pcm still see other sensor faults?) I.e temperature, barometric or pos??
And does the maf only monitor air flow/pressure? Not temperature?
This is all i can think of at the MO
Thanks for reading guys i know I'll probably hit a brick wall but I'm interested in all this!
hawkander wrote:thanks again , will try and do some work on it, when work and weather permits.
