MK 6/7) turning off the service light?
Re: turning off the service light?
Postby killbill » Mon Aug 13, 2012 8:49 pm
hi there
i have tried the methods mentioned but the service light just stays on.
tried holding both pedals for over 2 mins but still wont flash or anything.
54 plate transit 280swb 85ps
any ideas ??
thanks
killbill
Postby martynx » Thu Aug 16, 2012 8:30 am
killbill wrote:hi there
any ideas ??
thanks
If your brake lights aren't working due to a switch problem at the pedal that would stop the reset happening . On a mk7 a thick floor mat may stop gas pedal going down fully !
martynx
Postby martynx » Thu Aug 16, 2012 3:28 pm
You could disconnect the battery overnite, that could clear some gremlins !
martynx
Postby killbill » Fri Aug 17, 2012 10:47 am
Thanks for reply , I did have brake light issue,turned out to be the plug at cluster needing pushed tighter.
All works fine now. But still won't reset.
I will try pulling the batt overnight, will the key fob etc be affected at all ?.?
Thanks for reply
killbill
Postby martynx » Fri Aug 17, 2012 11:00 am
Just the radio security code to consider , if you need it plenty of members on here can generate it if you post the radio serial number up.. Your immo / key codes / remote will be fine..
martynx
Postby killbill » Fri Aug 17, 2012 10:33 pm
martynx wrote:Just the radio security code to consider , if you need it plenty of members on here can generate it if you post the radio serial number up.. Your immo / key codes / remote will be fine..
Got radio code on the handbook ;) thanks for that,
Hopefully it works,the spanner is annoying more than anything
killbill
Postby martynx » Fri Aug 17, 2012 10:53 pm
No problem & good luck & if that dont fix it , you could try clearing the DTC fault codes from the van , i reckon your close though :)
It does take a few goes to clear it in my experience , especially on a Mk7 ( I knows yours is a 6;) )
martynx
Postby killbill » Tue Aug 21, 2012 10:59 am
still no joy :( i pressume i need a reader of some sort to read the codes or does the transit have on board diagnostics ?
killbill
Postby Wildwind:57 » Fri Aug 31, 2012 1:13 pm
Holding the acellarator and brake pedals down for longer than the stated ten seconds ( about 40 seconds ) while turning the ignition key to position two with the side lights on worked for me guys. Transit 2002 280swb.
Wildwind:57
Postby DieselNoob » Fri Oct 19, 2012 1:47 pm
Hi All,
First post and it's a question (please don't shoot me). On my 54plate 350MWB Transit i've got a RED spanner (no oil can) showing in the top right of the dash, not down near the odometer. Does this relate to a fault code rather than a service interval? Are there two spanner symbol locations?
DieselNoob
Postby ake » Fri Oct 19, 2012 7:22 pm
DieselNoob wrote:Hi All,
That's a service light, it changed on later vans ;)
Postby DieselNoob » Wed Oct 24, 2012 11:12 am
Excellent, thank you. We have a few issues with the old bus and i wasn't sure if a fault code (if it was a fault code light) would be a good place to start.
Many thanks.
DieselNoob
Re: MK 6/7) turning off the service light?
Postby tengenesha » Tue Feb 05, 2013 4:42 am
Hi iam new to the forum,the service light spanner with oil is showing on my Ford 2.4 RWD minibus 2002 and the Engine will not start but just cranks,Vehicle was serviced 6months ago i intend to replace oil and filter and resetting the service light.
my question: is this normal for the vehicle not to start due to service light spanner/oil coming up or there is another issue,
tengenesha
Postby ake » Fri Feb 08, 2013 8:14 am
tengenesha wrote:Hi iam new to the forum,the service light spanner with oil is showing on my Ford 2.4 RWD minibus 2002 and the Engine will not start but just cranks,Vehicle was serviced 6months ago i intend to replace oil and filter and resetting the service light.
The service light will not prevent stat up. You have further problems
Postby speedyblue » Tue Mar 04, 2014 10:48 am
cheers mate thats sorted it
speedyblue
