Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby robbie.cee » Sun Aug 19, 2012 9:00 am
Well last day of tinkering (mixture, anti freeze and possibly oil change) then the the Essex v6 returns to Essex!!!! 8)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby AlanN » Sun Aug 19, 2012 10:10 am
Pop into Nicks on the way home :D we're here all day chopping up Nicks van
Postby transitandy » Sun Aug 19, 2012 12:51 pm
Dont forget to change your signature m8 :wink:
Postby Muttley » Sun Aug 19, 2012 7:08 pm
Top job and just in time, I will be interested in the MPG for this beast as I have the same plan for Shorty :D
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby jonochap » Sun Aug 19, 2012 8:10 pm
Awww, mate so happy for you that it all happened...2 new bubs in the house! :)
jonochap
Postby robbie.cee » Sun Aug 19, 2012 10:55 pm
Back in Essex now, after a fekin baking day. Van drives sweet, pulls great and the noise has died down on the timing gear
only down side seem to have slight fuelling issue with the fuel pump, might need a space in between pump and block? doesnt seem to be getting full stroke on the arm of pump, but pumped manually is fine! emptied the fliat chambers pretty fast on the a2 :lol:
Anyone confirm if there should be a spacer between pump and block? cheers!
Other than that im well chuffed with my new exhaust note, more power and prob more top end (but carb needs tweaking at some point) and once i sort the fuel pump its gonna kick ass! 8) =============================================
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sun Aug 19, 2012 11:01 pm
Other than that im well chuffed with my new exhaust note, more power and prob more top end (but carb needs tweaking at some point) and once i sort the fuel pump its gonna kick ass! 8) ============== 8)
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Sun Aug 19, 2012 11:32 pm
:D good to hear youve got her home, bet the neighbours will love you :lol:
Can you not just try the spacer to see what happens :wink:
Postby robbie.cee » Sun Aug 19, 2012 11:54 pm
yeah will have to try something heat proof like old balelite ones on some engines as pump gets hot!
Had
MAKE IT FIT
robbie.cee
Postby lampy54 » Mon Aug 20, 2012 7:47 am
I used to race the V6's back in the 80's/90's and had one in my mk1 transit 8) . If you run without a thermostat put a baffle plate/restrictor in the housing.
It pushes the water to the back of the block stopping the rear cylinders overheating, I used to have the back two cylinders bored sloppy as well due to heat build up.
My race engine put out 220 bhp :D.The one in my service barge 140bhp................. happy days
so many lamposts so little time........................stupid place to put a wall wasn't it
lampy54
Postby AlanN » Mon Aug 20, 2012 8:53 am
Didnt they have some sort of fibros spacer, looks like red leather stuff
Postby dieselhead123 » Mon Aug 20, 2012 3:07 pm
Glad I am not the only one who thinks there should be a spacer/gasket between the pump and the front case, :lol: :lol:
My local Ford Commercial agent are checking the SVO build info as I type, hopefully a positive outcome!
Postby AndyG » Mon Aug 20, 2012 3:26 pm
Like this?
Postby MinorMatt » Mon Aug 20, 2012 3:40 pm
or get an electric pump and blank the hole?
Postby dieselhead123 » Mon Aug 20, 2012 4:12 pm
AndyG wrote:Like this?
That's the kiddie mate, just what you need Robbie!
