Starter Battery and Leisure Battery
Postby DarrenK » Fri Aug 24, 2012 6:50 pm
Hi all,
My 89 camper, has the Vehicle and Leisure batteries under the bonnet. The leisure is connected to the starter battery to charge when driving. Problem is, that the last few times we've been out, the vehicle battery has died when camping. I disconnect the leisure battery today whilst all the lights were on in the van, and they stayed on.
Can anyone advise how i can stop the leisure drawing from the main battery please? we're off to Dorset on Tuesday, and i dont want to be left asking for a jump start again lol. :oops:
DarrenK
Re: Starter Battery and Leisure Battery
Postby whitemice » Fri Aug 24, 2012 7:08 pm
Probably time for a new split charge system. The lights in the back of the van should be fused and wired to the leisure battery only and it would appear yours are not.
These are ok and caravan/motorhome places will have similar and can fit cheap enough if you're clueless.
http://www.ebay.co.uk/itm/BONGO-VAN-SPL ... 2a2201166d
http://www.ebay.co.uk/itm/T5-TRANSPORTE ... 2574a57cb6
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby DarrenK » Fri Aug 24, 2012 7:21 pm
I really dont know how its wired, we've had her for 2 years (3 Summers), and its only this year we've had problems.
I think the lights are drawing from the Car battery through the linking cable, as we've never has anything to prevent it. So this system is guarenteed to stop any draw?
I thought there would have to be something in the actual link cables. But there is something else, Inside we have the hook up, with its elctrical fuse board, one of the fuses says lights? But, there isn't any 240v lights in the van lol.
DarrenK
Postby whitemice » Fri Aug 24, 2012 7:26 pm
You should have a split charge relay system and then the lights/freezer/stereo etc. are all isolated from main battery. If it's just got two wires connecting the batteries it's no good. Any connecting wires should be fused as close to positive of each batt as possible.
whitemice
Postby DarrenK » Fri Aug 24, 2012 8:50 pm
So does this mean, i fit it from the Main battery through to the Leisure battery, and disconnect the two existing cables leaving just the relay ones?
If so, then it seems to be very quick and eas fix, and no cables running up to the stearing column or alternator.
DarrenK
Postby whitemice » Fri Aug 24, 2012 10:56 pm
DarrenK wrote:So does this mean, i fit it from the Main battery through to the Leisure battery, and disconnect the two existing cables leaving just the relay ones?
Yeah, basically you tap the 'sense' ie 5v at the alternator to relay/processor(connector will be in kit) and run the relay/processor wiring between the batts.
Then you run a cable to the fridge from leisure batt @15A guage and another say 30A guage to your fusebox for all the pumps/lights etc.
Put fuses for everything as close as possible to batt positive terminals.
I do not even have the clock or vehicle alarm ultrasonics running from main batt, ie. zero draining when static. An unregulated 5-10w solar panel is handy to charge maintain the leisure battery when idle.
You will get instructions/diagrams with the kits and the two places suggested offer advice etc. it's a doddle really, just check and make sure every circuit in the van ie. lights/stereo/pumps are individually fused with the correct rated fuse/wiring and choose a fusebox feed wire guage to suit - ie. total everything and double it :mrgreen: .
I treated my MK2 amby camper to a pair of american rv plumbing type surface mounting solar vents last week as the original passive ones were past their 27 year sell by date, it makes a big difference having a positive extraction of air every day and they cannot be heard running........$21 a pop in sale promo 8)
whitemice
