ive got a 12 plate 90ps connect
it has a few strange issues
when pulling away all is fine but when i dip the clutch and release the throttle the revs rise slightly for about a second or two and then eventually drop, it may sound minor but it makes the van lurch and nasty to drive, this happens probably 80% of the time but sadly never when its at a dealers, it only seems to happen when changing from 1st-2ndand 2nd to 3rd
its been in twice already once they did something with the software and the second time they said they swapped the throttle
it used to stall quite reguarly when setting off but this seems to have stopped since the throttle pedal was swapped
any ideas or is this normal
