New owner needs advice.
Re: New owner needs advice.
Postby Bailey. » Thu Sep 27, 2012 7:52 pm
Some pics would be good. As said already just a little worried it will be to har for everyday use in rural roads. I see a lot of guys go with 18s. I'm tempted to go with 16's, but with a higher profile tyre. Which would be help with the
Absorbing of the lumps and bumps!??
Bailey.
Postby Mylee » Thu Sep 27, 2012 8:50 pm
I was running -40 on the front before the coilovers. It is an ideal set-up for what you want.
This is standard.....
This is approx -40.....
With axle flip on the rear
This is with coilovers, with the rear lowered further to match.....
Only thing I would suggest is to get the shortened rear shocks when you flip the axle.
Mylee
Postby valetech » Thu Sep 27, 2012 8:58 pm
if you run a 40mm front drop you wont have any problems with the roads you use.it will give you a prefect mix of ride height and stiffness,ride is comfortable.
40mm kit before on 18" ST alloys
after
rear now has a 3" gap
60mm front setup is a hard ride,if wanting to do this its a good idea to uprate the front shocks.its always a good idea to uprate the rear shocks with connect shortened shocks
60mm front drop
if you use standard rear hangers this happens (back end down)
molested by:
19s is how we roll
valetech
Postby Kent Discos » Thu Sep 27, 2012 9:22 pm
i now run the springs that mylee had....
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Media Group - http://www.kentmediagroup.co.uk | Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby Bailey. » Thu Sep 27, 2012 9:30 pm
Really like the look of the 40mm drop in mylees 2nd pic, that's spot on. What's are the price of these kits?
Bailey.
Postby valetech » Sat Sep 29, 2012 9:34 pm
molested by:
19s is how we roll
valetech
