Transit Connect Wheels HELP & Advice Please
Postby waynerp » Sat Sep 29, 2012 10:33 am
Hi All
I have a 53 SWB connect.
i have just bought some 2nd hand Renault Laguna 17" wheels to replace the standard wheels as they are rusted and shot.
Being a novice on this type of thing i had a look on the forum and it seemed the only numbers/ dimensions i needed for wheels is the PCD which is 5 x 108, which is what they are for the renault wheels.
i have just tried to fit them and it looks like the centre circular fitting is slightly to small on the renault alloys to fit. i haven't tried to push it on with any force as the vans only on a car jack.
Is there any other dimension that i need to look for ? should these wheels fit with a bit of force, or is there only certain models of wheel that will fit?
any suggestions or advice would be VERY much appreciated.
wayner
Transit Connect 53 plate SWB Silver
http://www.pcperfect.co
waynerp
Re: Trnsit Connect Wheels HELP & Advice Please
Postby gt_addict » Sat Sep 29, 2012 11:02 am
You should also check the offset of the Renault wheels. It's the distance from the centre of the wheel in to the outer edge I think. There might be an "ET" number stamped on the back of the wheel. Et45 is the ideal offset if I remember correctly. I wouldn't force the wheels on either as if you don't get them sitting flat then it will cause problems.
gt_addict
Postby g-man » Sat Sep 29, 2012 11:10 am
offset on laguna's are 35 so will be ok.......but wheel centre's are 60mm and connect is 63.4mm
g-man
Postby waynerp » Sat Sep 29, 2012 11:12 am
So is there anything I can do with these wheels. So kind of adapter of get them bored out?
wayner
waynerp
Postby g-man » Sat Sep 29, 2012 11:15 am
don't know mate,not a wheel expert.......safety?.....cost?
g-man
Postby Altransit » Sat Sep 29, 2012 11:18 am
g-man wrote:......safety?.....cost?
Not to mention insurance approval :?
Postby waynerp » Sat Sep 29, 2012 11:50 am
Good points.
Thanks for your advice. Think I will look for some focus wheels
wayner
waynerp
Re: Transit Connect Wheels HELP & Advice Please
Postby vanman46 » Sat Sep 29, 2012 5:51 pm
Prety sure I have seen and read that Lagunna wheels will fit was going to get a set for mine as they were a lot cheaper and not so sought after as ford wheels and I liked the BBS style they did . But picked up a set of mondeo alloys for a good price in the end .
Someone may come along on here and confirm if they will fit shortly
Connect 200 swb
Focus Airbox Mod
K&N Filter
Vantuner Remap
The Future's Bright , The Future's Orange
vanman46
Postby waynerp » Sat Sep 29, 2012 6:00 pm
I hope so mate, i cant believe how many different sizes and measurements there are for wheels!
wayner
waynerp
Postby vanman46 » Sat Sep 29, 2012 6:20 pm
Have you checked there is any corrosion around the lip of the alloy? that could be stopping it from seating correctly ?
Connect 200 swb
Focus Airbox Mod
K&N Filter
Vantuner Remap
vanman46
Postby waynerp » Sat Sep 29, 2012 6:25 pm
yes i gave it a light sanding before putting on as there was some corrosion,but it is as g-man said that the wheel centre's are 60mm for the laguna and connect is 63.4mm.
i'm sure they could be bored out, as its only 3.4mm but think that will cost more than the wheels!!
wayner
waynerp
Postby valetech » Sat Sep 29, 2012 9:31 pm
Fit a 5mm spacer.any bigger may need longer wheel studs
The correct numbers are
5x108 pcd et52.5
If running 18" then 7.5j 8j fit fine as well
molested by:
19s is how we roll
valetech
Postby waynerp » Sat Sep 29, 2012 10:18 pm
Excellent many thanks.
Any ideas where I can get spacers from?
wayner
waynerp
Postby waynerp » Sun Sep 30, 2012 8:04 am
sorted. ordered and impatiently waiting
thanks for all your help everyone
will add some photos when fitted
wayner
waynerp
Postby Ambowelly » Sun Sep 30, 2012 8:45 am
You need hubcentric spacers. If you just fit plain spacers, all the weight of the car, plus cornering etc, will be taken by the wheel studs and not the locating spigot on the wheel.
Ambowelly
