Had a lovely long lay in til 1230 this afternoon! whoops was gonna get up sooner!
wasnt all bad, by then sun was sort of out and it was warm ish so i jumped to it and started sorting out my new fuel lines and relocated fuel pump!
old Di shyte being replaced as its too easy to damage, and too near exhausts!
pull this off to gain extra access behind heat shields
test to see if pipe would go where i wanted it
theres access right at back on right side if you can get your hands in there
exiting from heat shield under van (return hose)
both flow and return, flow braded from carb to here, so is return but cant see as slightly shorter braiding
and pump power line, or 110v cable if your picky!
return from bonnet to tank along chassis rail
pump relocated
toyed with idea of fitting inline filter, toss up between pump life and less risk of air ingress... new hose used so i fitted it!
return will get hot still but least its not by a manifold.
need to get piccy of flow pipe in position, will do it tomo!!
next on list of jobs to do will be get seats fitted , bulkhead moved or chopped up, and windows fitted!
