03 transit connect 'HEATING NOT WORKING'
Postby poppeye » Fri Oct 05, 2012 4:29 pm
Hi, my heating doesnt work in my van, it just blows out cold air, i have the van about 3 months, when i first had it it worked once or twice, i then serviced the van and also flushed out the heating system and refilled it with coolent, the heating worked again for a couple of minutes and hasnt worked since which was a couple of months ago, can anyone help me please?
poppeye
Re: 03 transit connect 'HEATING NOT WORKING'
Postby CamsTrans » Fri Oct 05, 2012 4:45 pm
Coud be the heater dial.. Might be worth a look on ebay for one as a cheap way to tick a possible fault off the list?
58 Transit Connect swb LR 75 (Gone)
08 Mk7 Transit Limited swb LR 140 (Gone)
14 Transit Custom Limited swb 125 8)
CamsTrans
Postby poppeye » Fri Oct 05, 2012 5:41 pm
When I turn the the dial from hot to cold there's a difference in sound, would that mean the dial is ok
poppeye
Postby gt_addict » Fri Oct 05, 2012 5:42 pm
Did you make sure the rad hoses got hot after you flushed it? If not and they are Luke warm when the temp gauge is in the middle then you've got an air lock.
gt_addict
Postby john3022uk » Fri Oct 05, 2012 9:50 pm
There’s an inline valve in one of the pipes from the expansion tank to the thermostat, i took mine off today as i had no heat just cold air blowing, and used my compressor to blow air through it to clean it as they get gunked up, which stops the water from circulating
john3022uk
Postby poppeye » Fri Oct 05, 2012 11:39 pm
If it is an airlock how do I get the air out?
poppeye
Postby poppeye » Fri Oct 05, 2012 11:43 pm
To John 3022, is your heating working now that you blew the gunk out?
poppeye
Postby john3022uk » Mon Oct 08, 2012 6:23 pm
Yes heating is working now, looking at the expansion tank it’s the pipe on the right which goes to the thermostat, the valve is located closer to the tank and if you feel the pipe there will be a bit thats hard , have you also checked your thermostat is working.
john3022uk
