Change tape player for CD player
Postby civvyash » Fri Oct 05, 2012 10:22 pm
Hi guys,
First post on the forum, please be gentle!
I have bought a 03 connect today but it has a tape player, does anyone know how much it would cost to buy a cd player replacement and get them swapped over? Is there a certain model I need to buy?
Not really sure if any other info is needed but any help appreciated.
civvyash
Re: Change tape player for CD player
Postby Graham Taylor » Sat Oct 06, 2012 8:58 am
If your replacing with another Ford model then you need the 600 RDS as later headsets wont fit. Best to replace with a nice newer single din and fit a blank but again make sure its the right one. For some reason Ford fitted a 1.5 din headset upto early part of o6 then double din onwards which is an easier replacement. Quite a few posts on here regarding this and an easy job to do.
Graham Taylor
Postby Adam_84 » Sat Oct 06, 2012 9:05 am
If you are looking to replace the headunit then I might be able to help with a CD one as that's what I took out my van, can check on model number if your interested.
Cheers Adam
Adam_84
Postby civvyash » Sat Oct 06, 2012 1:55 pm
Thanks for the replies, I'm not entirely sure what's what with these, I'll add a photo later of what I have and hopefully someone can advise further.
civvyash
Postby civvyash » Sat Oct 06, 2012 2:04 pm
Adam_84, thanks for the offer if you could tell me what to check or what info you need i'll have a look.
civvyash
Postby Adam_84 » Sat Oct 06, 2012 7:16 pm
Hello mate here's some pics of the headunit:
Mine also had steering wheel control on it but I'd have thought there all made the same with just an extra harness plugged in.
Adam_84
Postby civvyash » Sat Oct 06, 2012 7:30 pm
nice one thanks mate i'll pull mine out tomorrow and see if I would be able to put yours in.
How much would you want? Can PM if you prefer.
civvyash
Postby Altransit » Sat Oct 06, 2012 7:44 pm
These .............................
................. are a straight swap for these................
.....................or these :wink:
Postby Adam_84 » Sat Oct 06, 2012 7:59 pm
Nice one Altransit, will have a think civvyash and pm you mate.
Adam_84
Postby civvyash » Sat Oct 06, 2012 11:53 pm
yeah cheers guys
I think mine says 6000 traffic?? not sure but will double check tomorrow.
civvyash
Postby civvyash » Sun Oct 07, 2012 1:19 am
Cheers Adam_84, it doesn't look like i can send PM's probably because I only just joined the forum. Yes that seems fine. I'll have a look at mine tomorrow and double check I can replace it with yours and then we can sort out payment etc.
civvyash
Postby civvyash » Sun Oct 07, 2012 4:19 pm
Adam_84, it's actually the 3000 tape player in mine. Would yours still be ok for a swap? is there any way I can check?
civvyash
