Restart after 16 years in the barn...
Postby YellowTransit » Sun Oct 14, 2012 5:44 pm
Dear all,
Coming tuesday, my friend Wim and I plan to fire up my old Transit (V4 1.7 petrol) after sixteen years of vacation... Anyone with experience with this? Should we just change the oil, or remove the sump and clean it out? What about old fuel - does it harm or should we clean out the system entirely before fireing up? Any other things to be aware of? All tips and advice welcome!
Very best,
Hans (with the yellow Transit - 1975).
YellowTransit
Re: Restart after 16 years in the barn...
Postby FredTransit » Sun Oct 14, 2012 6:18 pm
dont know if or how often you turned over the engine. First trx it by hand to check its not siezed. Piston rings can gum up and snap if you shock them! Yours has been laid up a long time so fresh petrol is a must. Traces wont hurt
FredTransit
Mk2 Trannyist
Postby FredTransit » Sun Oct 14, 2012 6:19 pm
FredTransit wrote:dont know if or how often you turned over the engine. First try it by hand to check its not siezed. Piston rings can gum up and snap if you shock them! Yours has been laid up a long time so fresh petrol is a must. Traces wont hurt
FredTransit
Mk2 Trannyist
Postby blue estate » Sun Oct 14, 2012 6:22 pm
Also a fresh set of plugs wouldn't go a miss and a fully charged battery
blue estate
Postby Neil » Sun Oct 14, 2012 8:02 pm
get a gallon of new fuel in a container and pipe it direct,/ bypass the tank , new battry and i reckon it will fire after a few cranks
Neil v6
Neil
Postby FredTransit » Sun Oct 14, 2012 9:27 pm
:? Dunno how or why l managed to quote meself?? :lol:
FredTransit
Mk2 Trannyist
Postby Luke » Sun Oct 14, 2012 9:33 pm
take the plugs out and squirt a bit of light oil into the cyls then turn it over by hand a few times - that should coat the bores then fire it up - it'll smoke the oil out but it's better than it picking up on the bores :D
Postby DodgeRover » Mon Oct 15, 2012 9:06 am
The fuel might still be OK IF it was filled with proper 4 star at the time not unleaded, it tends to last a lot better, however I would go with what other people have said and try it on a can first.
DodgeRover
Postby FredTransit » Mon Oct 15, 2012 10:30 am
I dont know where in the world the OP is, but leaded fuel has been gone from europe a long time. Back when we took a Mk2 to Germany in the late 80s there wasn't even LRP at the pumps. When did it go in the UK? LRP was still at the pumps during the fuel strikes though.
FredTransit
Mk2 Trannyist
Postby FredTransit » Mon Oct 15, 2012 10:41 am
YellowTransit wrote:Hi there,
My name is Hans and I live in The Netherlands.
ah, thought Hans wasn't in the UK
FredTransit
Mk2 Trannyist
Postby YellowTransit » Mon Oct 15, 2012 2:30 pm
Thanks guys, for the good advice!!! About the fuel - as I remember I did indeed fill it up with leaded fuel ("Super" leaded) at the time I actually used it - somewhere 1993. Tomorrow is the big day... will let you know what happened.
Very best,
Hans
YellowTransit
Postby baconsdozen » Tue Oct 16, 2012 1:23 pm
I like to take the plugs out,pull the feed off the coil and spin the engine on the starter untill the oil light goes out.
Best of luck,hope it all goes well for you.
baconsdozen
Postby whitemice » Tue Oct 16, 2012 3:21 pm
baconsdozen wrote:I like to take the plugs out,pull the feed off the coil and spin the engine on the starter untill the oil light goes out.
Agree with that, like Luke said too some light oil would not go amiss, ATF/MMO through the plugholes and left a while will free any gummy rings.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby YellowTransit » Wed Oct 17, 2012 10:25 am
Hey chaps - we only had some minor setbacks yesterday - messed up the ignition leads first (we were a bit in the dark what connection on the distributor cap should lead to cylinder 1) and we did not get a spark instantly (braker points looked fine but still needed a touch with sand paper, so it appeared) but then... sunshine! It started as ever before. Cylinder 2 seemed te be a bit less active... I will check the combustion pressure tomorrow - then perhaps will decide to repeat the treatment with thin oil if the compression is less than normal...
Best, Hans
YellowTransit
Postby FredTransit » Wed Oct 17, 2012 7:21 pm
erm after 16 years you charged straight in and turned it over? Damn you were lucky!
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
