After Market Alarm Suggestions
Postby waynerp » Sat Oct 20, 2012 8:46 pm
Hi ALL
i am thinking about getting an after market alarm for my 53 connect.
i assume the connect has some form of factory fitted immobiliser as standard? or is it just central locking?
if not can anyone recommend any after market alarms?
Many thanks
wayner
Transit Connect 53 plate SWB Silver
http://www.pcperfect.co
waynerp
Re: After Market Alarm Suggestions
Postby dieselboy1978 » Sat Oct 20, 2012 9:53 pm
I had a cat 1 thatcham approved alarm fitted.
Locks all.doors with a remote fob.
Very good alarm.and fitted by a guy i found on ebay.
If your interested let me know and i can pm number
Bank account emptied by
DELPHI
dieselboy1978
Postby Kent Discos » Sun Oct 21, 2012 2:05 pm
i had a toad A850 on mine fitted by a local dealer, just plugs into the existing immobiliser unit and made it Cat 1 :)
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Media Group - http://www.kentmediagroup.co.uk | Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby liteace » Sun Oct 21, 2012 6:08 pm
Kent Discos wrote:i had a toad A850 on mine fitted by a local dealer, just plugs into the existing immobiliser unit and made it Cat 1 :)
Does he A850 use its own fob or the Ford fob, I want an alarm on mine but I dont want to muck up the locking that is got at the mo, 3 button key so I can work the front doors independently from the rear doors
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby paul_h » Sun Oct 21, 2012 9:05 pm
I've got a toad ai606 on mine. Seems todo the job perfect. Have a ongoing problem with the back doors not locking but I think that's todo with the vans wiring loom/ lock mechanism
paul_h
Postby get connected » Sun Oct 21, 2012 9:32 pm
I fitted a Toad A850 to my Connie, it uses the existing Ford fob..... Great bit of kit and easy self fit...
Keep a smile on your face at all times! The others think you know something that they don't !!!
get connected
Postby waynerp » Mon Oct 22, 2012 7:27 am
get connected wrote:I fitted a Toad A850 to my Connie, it uses the existing Ford fob..... Great bit of kit and easy self fit...
having a quick read up, do you need to have remote central locking for the A850 to work?
mine has central locking but not remote central locking
wayner
waynerp
Postby dieselboy1978 » Mon Oct 22, 2012 9:16 am
Mine had central locking but no remote central locking as wasnt fitted.
Alarm guy now has my van remote central locking. Unlocks front doors with 1 unlock and then side loading door and rear doors on 2nd unlock.
DELPHI
dieselboy1978
Postby liteace » Tue Oct 23, 2012 8:31 am
These Toad A850 alarms, are they only armed \ disarmed with the remote , what happens if the fob battery goes flat and you have to use the key to open the van how do you switch the alarm off
liteace
Postby Kent Discos » Tue Oct 23, 2012 2:09 pm
it disarms when the door is unlocked with the key, they also have a pin code switch too that you can disarm it with.
Kent Discos
Postby valetech » Tue Oct 23, 2012 2:21 pm
Kent Discos wrote:it disarms when the door is unlocked with the key, they also have a pin code switch too that you can disarm it with.
:shock:
whats the point of that then?
i can unlock a connect without the key! not going into info on here on how to
molested by:
19s is how we roll
valetech
Postby Kent Discos » Tue Oct 23, 2012 3:31 pm
transponder chip in the key im guessing
Kent Discos
Postby get connected » Tue Oct 23, 2012 6:23 pm
Ok, the A850 takes its triggeres to arm and disarm from the central locking system of the vehicle, whether it's fob operated or key operated. I've wired mine to only set by the second press of the fob, i.e. double deadlocking. Therefore if the next time the vehicle is unlocked and it was only set with one press it goes off instantly, this reminds me to always double lock Connie!
For those of you without remote locking a seperate radio fob and receiver can be added, these are available from the likes of CPC Farnell on the 'tinterweb...
Hope this sheds a little light on matters...
Cheese Dave :wink:
get connected
Postby waynerp » Tue Oct 23, 2012 9:18 pm
So would you say the A850 is something your average bloke could fit ??
Not that i'm saying i'm average, i'm a easy 8 out of 10
but very average with electrics on a van !!!
i'll shut the F**k up now
wayner
waynerp
Postby liteace » Tue Oct 23, 2012 9:28 pm
I agree, what is the point of that, I want something that is not disarmed by the key just incase
liteace
