Caravanette Mot
Caravanette Mot
Postby pictishpunkgirl » Sat Dec 16, 2006 2:52 pm
The guy at the garage said that if our van was a caravanette, then it would be a class4 instead of 7 and could then be moted less strictly, if this is the case, what would need to be done to class it as a caravanette, and would it be harder or more expensive to insure it?, If there is anyone with experience in this sort of thing, their advice would be appreciated.
Mike
pictishpunkgirl
Postby motorwise » Sat Dec 16, 2006 4:38 pm
whats the gross vehicle weight? (GVW on the chassis plate)
http://www.motorwise.net
motorwise
Postby pictishpunkgirl » Sat Dec 16, 2006 6:16 pm
3.5 tonnes but he said it could still be a Class 4 if it was a caravanette, despite the weight. True or false? :D
pictishpunkgirl
Postby MrMPuk » Sat Dec 16, 2006 6:29 pm
pictishpunkgirl wrote:3.5 tonnes but he said it could still be a Class 4 if it was a caravanette, despite the weight. True or false? :D
Correct, normallly a van between 3000kgs and 3500kgs then it requires a class 7 MOT but if it's registered as a motorhome then it can still be MOTed as a class 4.
Class 4 MOT
Postby welshrussell » Sat Dec 16, 2006 6:45 pm
I've just looked at my 1976 MK1 MOT, and it says Class 4.
Can anyone tell me what I will get away with compared to a Class 7?
I'm thinking along the lines of rusty wings :(
Cheers!
Do good things - and good things will happen to you!
welshrussell
Postby MrMPuk » Sat Dec 16, 2006 7:35 pm
You can have rusty wings but you can't have sharp edges or bits about to fall off.
Postby Neil » Sat Dec 16, 2006 9:29 pm
what test do the big yankee motorhomes have then or the iveco :?:
Neil v6
Neil
Postby MrMPuk » Sun Dec 17, 2006 3:32 am
Neil wrote:what test do the big yankee motorhomes have then or the iveco :?:
If you are talking about vehicles over 3500kgs, then they require a HGV test from the date they are 1 year old and every year then after.
Postby Neil » Sun Dec 17, 2006 2:33 pm
so does puttin windows in alter the gvw :?:
Neil v6
Neil
Postby pictishpunkgirl » Sun Dec 17, 2006 3:02 pm
So does anyone know what you have to do to the vehicle to change it from a van to a caravanette?
pictishpunkgirl
Postby pictishpunkgirl » Sun Dec 17, 2006 6:41 pm
pictishpunkgirl
Postby MrMPuk » Sun Dec 17, 2006 8:03 pm
Neil wrote:so does puttin windows in alter the gvw :?:
I don't make the regulations Neil!
Postby XLB » Sun Dec 17, 2006 8:50 pm
Unless it's a motorcaravan, then it's 3 years! Class 4 MOT regardless of weight! Old coaches etc fitted out as motorcaravans (not race transporters, they're different) are class 4 MOT.
XLB
XLB
Return to Transit Talk
