My mk6-7 Front End Conversion photo album
Re: My mk6-7 Conversion photo album
Postby kevinwalkerjnr » Sun Sep 11, 2011 10:34 pm
stephenferguson wrote:which part mate that link shows a transit?
Hi
Yea that's mine pre facelift. The part I was asking about is the air intake you mentioned you would be adding.
Then you have pic on link. One of last photos.
Is this part necessary. Does it connect to any existing mk6 air intake.
kevinwalkerjnr
Postby kevinwalkerjnr » Mon Sep 12, 2011 11:25 am
stephenferguson wrote:I have been modifying the headlight connections over from the mk6 loom to mk7 headlight, part of the front end conversion. There was two little faults, one being the headlight leveling didnt work and the second (not really being a fault just me being particular) being the indicators on the mk6's have a separate plug for the indicators.
To sort the headlight leveling, it was a simple case of moving one of the earths in the plug from pin 1 to 5. This gives the headlight leveling motor its earth to work.
To sort the indicators so that they work from the main plug, I cut the plug off the harness, loose the black (earth) and tape/tuck it away into the harness, then extend the +ve wire, tape it into the loom so its nice and neat and push it into pin 1 on the main headlight connector.
Hi
I'm amazed at the amount of information you are supplying regarding conversion
I have been thinking and asking these things for months before I started my upgrade.
Mines in paint shop but I know these little things are going to need to be addressed.
So were above you say regarding self levelling and indicators in mk7. Are your mods to the mk6 plug ? Does moving earth to pin 1 not leave another bulb unearthed ?? Or did you take a spur-feed from it and does the cut plug indicator earth become unusable and you just relocate the + ?
cheers kev
kevinwalkerjnr
Postby stephenferguson » Tue Sep 13, 2011 8:27 pm
All mods are to the mk6 harness plug.
There are two earths in the plug in total i think...
The +ve and -ve i cut were the indicator bulb wires on the harness its self as, on the mk6 headlight, the indicator bulbs have there own plug, where as on the mk7 headlight the indicator is fed from the main headlight plug
...if that makes sense.
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby dazrecoverymad » Wed Dec 28, 2011 1:37 am
Sound job nice to look at the progress
dazrecoverymad
Postby stephenferguson » Fri Dec 30, 2011 11:24 pm
Cheers daz, i hopefully will be getting it sprayed in the new year!!
stephenferguson
Postby andy4 » Tue Feb 07, 2012 9:15 pm
Hi mate I've got most of the parts needed to do the conversion but lack the skills or anyone local to me to carry the work out.
I wondered whether you would take on doing the conversion for me and if you would how much would you charge / how long would it take.
Please pm me if your interested.
Andy
andy4
Postby bootz 1 » Fri Feb 24, 2012 9:49 pm
Big job fella fair play looks the part. Would u recommend me doing it? Was it difficult?
bootz 1
Postby surplus 6 » Fri Apr 13, 2012 11:50 pm
stephenferguson wrote:MK7 FRONT END INC. DOORS, WIPER MOTOR, RADIATOR, PLASTICS ETC £450
SCUTTLE PANEL AND INNER WINGS £110
CHASSIS PLATES AND STRENGTHENER £15
HEATER DUCT PART £12 *
WINDOW FITTING £40 *
MK7 HEADER TANK AND MK7 FUSE BOX BRACKET £40 *
LABOUR TO FIT £250
THEN I GOT £370 FOR MY OLD FRONT END (STILL GOT MK6 DOORS (ELECTRIC WINDOWS), MK6 WIPER MOTOR, MK7 RAD FAN, FULL MK7 STEERING COLUMN TO SELL SO)
TOTAL SPEND £547. :shock:
* = THINGS PROBABLY NOT NEEDED, JUST ME BEING A FANNY!!
yeah you need the the mk7 bonnet lock, i took the tumlers out of mine and fitted into the mk7 lock. plus mine was rusted to bits!
for everything else there's mastercard :lol:
surplus 6
Postby 75psT330lwb » Fri Apr 13, 2012 11:54 pm
been there done that :o 8)
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
Custom Ecoblue
75psT330lwb
Postby andyglx » Thu Jun 07, 2012 11:03 pm
good skills.
andyglx
Postby dazrecoverymad » Tue Oct 23, 2012 10:45 pm
good work there how much did you cut of the chassis legs is it a square cut all the way round?
dazrecoverymad
Postby stephenferguson » Tue Oct 23, 2012 10:50 pm
Cant remeber how much daz but it is a square cut as the new cross member is a flat fit. It wasnt much of a cut, and inch or so on the inside, best thing is to measure off some factory holes in the chassis on a mk7 :wink:
stephenferguson
Postby dazrecoverymad » Tue Oct 23, 2012 10:54 pm
thanks ,just got my hands on a low milage 54 plate tipper its a prime candidate for the conversion .can you get away without taking screen out or is it a must? thanks ,
how do you recon it stands legally cutting the chassis?
dazrecoverymad
Postby stephenferguson » Tue Oct 23, 2012 11:24 pm
Yes theres no need to remove the screen, can be spot welded underneath, i only took out as it ha about 5 screens in before as my dad was a welder and kept on splattering screens, and the glue on top of glue hadnt sealed properly which had caused it to leak!
stephenferguson
Postby hillman » Thu Nov 01, 2012 4:22 pm
stephenferguson wrote:Here are the pics to how i have done it, any info needed just ask.
http://s873.photobucket.com/albums/ab29 ... onversion/
I just put the bumper on today and mounted the under bonnet parts correctly, so i'll get a pics added tomorrow.
hi stephen
i'm just about to start mine in the next couple of weeks and i have a couple of questions please
1 how much do you have to cut of the chassis
2 if my headlight units dont have the correct indicator fittings how do you modify
3 did you fit mk7 electric doors and how do you wire up the connections,my mk6 has not go electric windows
I'm getting my parts next week and hopefully i may then make a start and i'm sure there will be other questions as i go along!!! would you mind if I ask for info.
thanks
hillman
hillman
