Gas bottle layed down under van !
Postby ajpmsport » Wed May 09, 2012 11:19 pm
Hi. If i was to make a hinged craddle up and fix to the underside of the van. Make it so its protected from all the road rubbish flying in there. The gas bottle would be on it`s side, is that a problem ? Also it would be a pain to turn the gas off every night and on again in the morning. Do most people do that or just leave the gas on when parked up ? :?:
THANKS
ajpmsport
Re: Gas bottle layed down under van !
Postby TIMO » Wed May 09, 2012 11:21 pm
I dont think the bottle will be effecient lying down tbh , not to mention safe , btw the bed idea in the other thread looks ideal :D
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby Altransit » Wed May 09, 2012 11:22 pm
You're not supposed to transport bottled gas in a lying down position, and you definitely shouldn't try and use it in that position :shock: :wink:
Postby ajpmsport » Wed May 09, 2012 11:33 pm
Altransit wrote:You're not supposed to transport bottled gas in a lying down position, and you definitely shouldn't try and use it in that position :shock: :wink:
OK thanks, saves me scratching my head over it any more. A sealed locker inside it is (with a floor vent) :(
ajpmsport
Postby TIMO » Wed May 09, 2012 11:36 pm
Yes And Yes im afraid mate :| theyre sh*t hot on that kind of thing .
TIMO
Postby TIMO » Wed May 09, 2012 11:39 pm
You could cut through the floor and weld in a compartment so that you dont take up too much internal space maybe?
TIMO
Postby bigjohnthomas » Thu May 10, 2012 8:16 am
What about those fancy bottles that forklifts use They are made to be used sideways? :?
bigjohnthomas
Postby scotty281976 » Thu May 10, 2012 8:32 am
bigjohnthomas wrote:What about those fancy bottles that forklifts use They are made to be used sideways? :?
they are totally different, the ones for fork lifts are liquid take off the hose goes to a vapouriser on the fork lift which turns it in to a gas. on regular bottles it has to be upright for to come out as gas
2011 mk7 ex rac 140t330 awd
scotty281976
Postby BootsBoots » Thu May 10, 2012 5:40 pm
Hi,
My AutoSleeper camper, transit 1987, pop top, has a tin box with a hole in each corner, underneath and the gas bottle is stored in it upright, and it has a lift out lid that closes it all up and that keeps the draft and any gas leakage out.
It takes the red/blue bottles that are about 12" - 15" in hight, unsure of the gas weight and they are put in/out from the top.
The majority of the copper gas pipe is routed under the floor coming up near the fridge & cooker.
Boots
BootsBoots
Postby ake » Fri May 11, 2012 6:57 am
Gas bottle must be stored and used in an upright position or you could end up with liquid gas at your burner, this would most likely result in the loss of your van in a huge fireball.
As said only proper liquid take off bottles (commonly on forklifts) can be used on there side
Postby Homersaysdoh » Tue Oct 16, 2012 9:07 pm
Bottled gas is stored under pressure, and as other posters have said should be used upright, butane and propane are roughly twice the weight of 'air' and half the weight of water, and any leaks will run down an gather in any nooks and crannies hence drop holes to allow escape, it will float on water and should not be stored near open drains, gas bottles rarely explode they have a safety valve that blows off, still nasty! Explosions are normally caused by pockets of leaked gas, yellow flame at burner point indicates inefficient burning (too much air). If your bottle is frosting up you are pulling off too much gas too quickly, all this from memory in a previous job years ago hope it helps, sure all available on the net from people like Calor
A cynic, someone who knows the price of everything but the value of nothing
Homersaysdoh
Postby Graham-sEY » Sun Oct 28, 2012 1:44 am
Hi, quick question, I'm going to be using propane during the cold weather.
Will the bottle have to be stud outside while in use, or can it be kept in the gas locker, and used from there :?:
Turned off when on the move.
Graham-sEY
Postby ursus » Sun Oct 28, 2012 9:55 am
It will be fine inside as long as there's no leaks.
ursus
Postby Graham-sEY » Sun Oct 28, 2012 11:59 am
Cheers thanks for that, didn't fancy leaving it outside cos i do alot of wild camping, and you don't know who's roaming about outside during the night.
Didn't want to wake up and find bottle gone and its to cold to run off butane. :D
Graham-sEY
Postby ursus » Mon Oct 29, 2012 6:22 pm
Indeed.A mate of mine was parked-up with her gas bottle outside(connected up),and about 7am one morning some toe-rag decided to cut the hose and stole it.
ursus
