banana engine into mk2 ? plus steering rack
Re: banana engine into mk2 ? plus steering rack
Postby oldyellar » Sun Nov 11, 2012 2:27 pm
big gux wrote:A YORKS BEST FRIEND IS A CAN OF BRADEX EASY START MATE GET IT OUT AND PUT A DI IN HER
depends if its a york or a micra(york with glow plugs) as we call them
oldyellar
Postby big gux » Sun Nov 11, 2012 3:25 pm
you will see a threaded piece with a lock nut on it undo lock nut and wind threaded piece and have someone gently rock it left too right you should feel the difference jack it up and get wheel couple inch off floor before starting too adjust it
big gux
Postby GavSuz » Sun Nov 11, 2012 4:33 pm
its a 2.4 diesel - 2360cc - has di on top of the air filter cover
the threaded piece is already wound all the way in on steering box - does that mean theres no adjustment left on it ?
GavSuz
Postby big gux » Sun Nov 11, 2012 5:43 pm
just try winding it out a little nothin lost nothing gained bit of initative mate thats all
big gux
Postby Muttley » Sun Nov 11, 2012 5:57 pm
The Di is 2496cc, dont know why you have a Di airbox :? Does the engine have glow plugs? Yorkies give good service as long as they are serviced well, my Yorkie has the glow timer bypassed and a button operating a starter solenoid allows me to heat 'em up for a bit longer :D Dont wind the adjustment out as it will make matters worse, slacken the nut and screw the inner part until it contacts inside the box, back it off a 1/4 turn and lock up. if you still have play the change the box :wink:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Return to Mk 1 & 2
