Ford Transit Connect ABS Warning Light....
Postby rob19 » Mon Nov 12, 2012 9:10 pm
hi, can anyone help, i have a Transit Connect and the ABS warning light is not illuminating when the ignition is switched on. Fuses are all ok, is there a relay? if so does anyone know where it is? any help or advice will be appreciated, thanks Rob
rob19
Re: Ford Transit Connect ABS Warning Light....
Postby Dub-77 » Mon Nov 12, 2012 9:51 pm
does the abs work? Maybe some one has had the clocks out and wedged blue tack down the hole where its meant to be like on mine :lol:
Dub-77
Postby Lefty64 » Mon Nov 12, 2012 10:02 pm
If you've got a base version SWB van (T200) then ABS is an extra-cost option.
It may not be fitted - so no check light will appear.
2007 T230LX LWB (110PS) with aircon.
Vans are designed for people with imagination. Cars are so limiting ... what can you do with them?
Lefty64
Postby g-man » Mon Nov 12, 2012 10:08 pm
rob19 wrote:hi, can anyone help, i have a Transit Connect and the ABS warning light is not illuminating when the ignition is switched on. Fuses are all ok, is there a relay? if so does anyone know where it is? any help or advice will be appreciated, thanks Rob
what year/model is it?
g-man
Postby rob19 » Mon Nov 12, 2012 10:20 pm
thanks for reply, it has got abs 57plate abs fitted as std from 04
rob19
Postby Dub-77 » Mon Nov 12, 2012 10:26 pm
rob19 wrote:thanks for reply, it has got abs 57plate abs fitted as std from 04
Really ?? I didnt know that. As i asked does the abs kick in or does it skid?
Dub-77
Postby rob19 » Mon Nov 12, 2012 10:28 pm
thanks for reply t230 57plate
rob19
Postby blue estate » Mon Nov 12, 2012 10:30 pm
Have you checked your reg in etis?
blue estate
Postby Ott83 » Tue Nov 13, 2012 12:34 am
blue estate wrote:Have you checked your reg in etis?
etis?
Transit Connect parts available here:http://stores.ebay.co.uk/VanBits4U
Ott83
Registered Trader
Registered Trader
Postby CamsTrans » Tue Nov 13, 2012 12:37 am
58 Transit Connect swb LR 75 (Gone)
08 Mk7 Transit Limited swb LR 140 (Gone)
14 Transit Custom Limited swb 125 8)
CamsTrans
Postby Dub-77 » Tue Nov 13, 2012 7:31 am
I give up
Dub-77
Postby valetech » Tue Nov 13, 2012 9:22 am
I give up
:lol: i fill your pain
molested by:
19s is how we roll
valetech
Postby Dub-77 » Tue Nov 13, 2012 7:28 pm
valetech wrote: :lol: i fill your pain
I tell ya it's hard work sometimes trying to help out :lol:
Dub-77
