by Sachmo » Sat Sep 24, 2011 11:44 am
Hi Ake,
I had a chat with a local independent mechanic - he said that if the egr is blanked mpg will decrease, the engine would burn more fuel and be less efficient.
Now I' am unsure what to do with the egr! Whether to blank it off or not.
I thought that with the egr blanked = less crud in system ie.. inlet manifold, and the engine would be better for it, with out the loss of mpg?!
What is best to do with the egr? Also If I blank it off will the sensor/s lights come on and stay on?!
Ake....Is it possible to just unplug the main switch off the top of the egr valve, and leave this off, then remove vacuum pipe at top and block this with a bolt or similar that would put an end cap on, therefore blocking the vacuum. If the above is done - is this not the same as blanking the egr, and pipe?
Taa.
Ford Transit T260, Soon to be done: Re spray in Dark Silver, K&N Air filter, Alloys, Underseal Wax/oil, Mark 7 Rear lights, Upgrade Audio Player, ECU re-map -75ps to 100ps, HID Lights front.
