Hi Lancy. We have tried lots of different 'set-ups' with this van, just to see what could be achieved and what we could get to work. From day one the 2.2 showed that more torque was available, with the longer stroke of this engine we sort of expected this.
Initially we ran a 115ps 2.4 Vp44 pump, 115 Transit 2.4 injectors and a 115 2.4 Transit PCM to 'match' the later 'digi' Transit cluster we had fitted. This all worked fine, was reliable, with no noticeable increase in consumption when driven as if it were a standard Transit, but has lots more 'get up and go' when asked for. We tried a VNT turbo on the engine, (with the vanes held fully open), full throttle acceleration was excellent. But, this won't work using a Transit Tddi PCM as the PCM does not have the facility to control the VNT, although it did show that having a VNT fitted and correctly working would give a lot more performance.
We now needed a Tddi PCM that had VNT control capability, the early Tddi Mondeo fitted the bill perfectly as it not only had a VNT turbo but also had cruise control, frost warning lights and other features only found on Mk7 Transits.
But we wanted to see if we could 'enable' some of these additional 'features' by using the Mondeo 115 Tddi PCM.
One of the main 'let downs' of the Mk6 is that Ford didn't offer cruise control, by using the Mondeo 115 Tddi PCM we could keep the Tddi management system and use the Mondeo cruise control.
I can't say if the Transit digi cluster will work with the Mondeo PCM as we didn't try this parts combination, preferring to use the better looking Mondeo cluster as it has a 'cruise on' warning lamp.
So, fit the Mondeo Tddi PCM, early models have VNTs, fit the Mondeo cruise steering wheel and add all the additional sensors and wiring to the Transit wiring looms.
I'll get some pictures posted up of the additional sensors we fitted.
