Transit Turbo Diesel Injector Pump
Postby tim » Mon Feb 13, 2006 11:14 pm
crazyscoot wrote:Tim.....how you getting on with the pump mate? Is your epic :cry: still playing the fool
Got the tee shirt mate.Changed the pump for a bosch pump from a 98-2000 smiley, the pump # has to end with 146.Changed accelerator and cable from same donor van.Changed injector pipes and changed fuel line pipes.Wired the solenoid to the ignition,so that got rid of all the electronics and that silly anti theft device.When started up it went like sh~t soi drove it to my local injector pump man who duly upped the fueling,not sure of the settings but it matched the pressure needed for the original blue colour injectors which i did not have to change.There was nothing done to the torbo.Driving now for over a week and i will never look back.Only a very slight difference power wise and that is on a long hill with 3.5ton up.Much more mpg and loads of low down pulling power,could stay in fifth all day
A WORK OF ART IS A JOY FOREVER
tim
Postby cossy tranny » Tue Feb 14, 2006 12:42 am
same here some conversion pulls in 5th no prob :D
cossy tranny
Postby crazyscoot » Tue Feb 14, 2006 6:04 pm
Opps ....forgot to mention the butterfly valve in the top of turbo needs to be wedged open. Mine drove like s#*t for a few days then took it back and they had forgot to open the butterfly valve. They pinned it fully open but eventually it worked loose......so i removed it altogether!
As you say performance is as good if not better and hills just dont seem to phase it one bit. The other thing i did was turn up the fueling on the pump and turn the tickover down (you have to do both) Ive got it turned up as much as i could without it blowing black smoke out the back. Just remember if you do turn up the fueling.......the pump is only rated to
bosch 4320 to 4560rpm
lucas cav 4280 to 4480rpm
Full load 4000rpm
I NEVER EVER drive it over 4000rpm. So if you do it, dont exceed these parameters coz she blow!
And just to add............mines given me approx 50,000 miles of trouble free motoring since doing these mods.
Glad you got it sorted mate! :D
Negative reality inversion
crazyscoot
Postby chrisuk » Tue Feb 14, 2006 8:34 pm
crazyscoot wrote:And just to add............mines given me approx 50,000 miles of trouble free motoring since doing these mods.
Which shape/engine tranny is this since doing the mod
chrisuk
Postby crazyscoot » Tue Feb 14, 2006 11:21 pm
Its a 2.5td 100 swb smiley1995
crazyscoot
Postby tim » Wed Feb 15, 2006 12:16 am
cossy tranny wrote:same here some conversion pulls in 5th no prob :D
Just a matter of interest,did you change your injectors
tim
Postby crazyscoot » Wed Feb 15, 2006 6:48 pm
No Tim, but would be interesting to maybe swap em, just to see how she drives then.
Couldn't tell you what colour mine are either as rust has set in on the caps where the dot is!
crazyscoot
Postby crazyscoot » Thu Feb 16, 2006 7:30 pm
Oh no! i spoke to soon! got a whiff of diesel today, checked under bonnet and one of the injectors is leaking......god dam, Knew i shouldn't have opened me big gob :lol: Anyway reason for telling you is that i spotted the colour of the injectors (id been looking at the rusty cap for the colour! :lol: ) anyway just to answer a post from the other day They're pink :D . Not sure what this colour means. Are there better ones :?:
crazyscoot
Postby MrMPuk » Thu Feb 16, 2006 7:32 pm
Doesn't pink mean you're a poof? :lol: :lol:
Postby crazyscoot » Thu Feb 16, 2006 7:50 pm
Dont think so :( ......i'll ask ford..........think they'll charge for the information :D
Changed my mind! they're not pink! they're PURPLE......so there! :D
crazyscoot
Postby MrMPuk » Thu Feb 16, 2006 7:51 pm
Not Salmon then!
Postby crazyscoot » Thu Feb 16, 2006 7:59 pm
MrMPuk wrote:Not Salmon then!
Wheres me paint pot
There, see they're white :D
crazyscoot
Postby tim » Thu Feb 16, 2006 11:46 pm
crazyscoot wrote:Oh no! i spoke to soon! got a whiff of diesel today, checked under bonnet and one of the injectors is leaking......god dam, Knew i shouldn't have opened me big gob :lol: Anyway reason for telling you is that i spotted the colour of the injectors (id been looking at the rusty cap for the colour! :lol: ) anyway just to answer a post from the other day They're pink :D . Not sure what this colour means. Are there better ones :?:
:oops: :oops: :oops: Pink,are you sure.On the epic pump system for the turbo diesel they are blue.On the N/A they are red on some green orange white on others i think it has something to do with horse power and pump pressures.I dont think Ford even know
tim
Postby madmark » Fri Feb 17, 2006 4:52 am
:shock: i will have alook at mine ,as i am shure i am going to be under the bonnet all weekend ! :(
Re: Transit Turbo Diesel Injector Pump.help
Postby jiggymuscat » Fri Feb 25, 2011 11:16 pm
hi,i need to know some things and if anyone could help...i own a 92 lwb whit a 25td engine,i just bought 2 weeks ago and i noticed that was with the epic mode now its manual....they fitted a cav pump from a di engine non turbo,
i need to know if i am going to get problems with the cav pump since its not for turbo engine? im hearing engine making some rough noise when i rev suddenly by hand a noise like this grr grr and then ok,it runs very good but im worried,everyone tells me that that kind of engine works a little noisy,but i dont know coz its my first transit ive owned!!
another question is that when i start the van in morning smokes a bit white then after i rev a little the engine and its fine,so what do you think??
thanks in advance for any reply
jiggymuscat
