Luke's 24v cosworth into mk1/2 thread!!!
Postby Luke » Sat Nov 04, 2006 7:51 pm
Well as most of you know im fitting a V6 24v cossy engine into my mk2 fronted mk1 :D I'll post the progress as i get on in this thread :D I know there are a few others doing it but, we cant have too many 24v cossy transplant threads can we :lol:
So this is how im doing it :D
My donar car is a 92 J reg scorpio BOA engined, but has the more complecated wiring loom - apparantly :( but it doesnt put me off really theres plenty of info/help on the net if i get stuck :D
to make it easier ive also got a mk3 2.9 V6 12v ambilance to use the gearbox (although we suspect it is the same as a standard transit one), adapterplate and engine mountings :D
as far as fitting it in the van the only differece between the mk1 and the mk2 is the room under the bonnet i should be fine as the mk2 has the most room :lol: but anyone wanting to fit one in a mk1 you'll need the bullnose front or cut away the bulkhead :!:
Postby dipstick » Sat Nov 04, 2006 8:53 pm
Luke, the gearbox is the same, i have 3 at the mo', and they are identical, on the outside anyway; a 2.5 Di MT75, a 2.9 Mt75 and an unknown Transit MT75..... :-)
good luck :-)
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Sun Nov 05, 2006 10:29 pm
well this weekends work - basically nothing nearly got the box off the amby v6 - to get at the apapter plate when i dropped the prop on my fingers :x but on the plus side i'd got the box crossmember off - i thought it would bolt up the same as the mk2 one i have fitted but its different so i'll have to modify it :?
on a side note - im looking at fitting the cruise control off the scorp - as far as i can find out it will fit 8) all i need is another pedal switch to go on the clutch :D i think it would be worth the hassle as its something i'd use - unlike the air con, with is prolly more hassle than its worth :?
Postby Luke » Sat Nov 11, 2006 4:00 pm
Just got the box off, does look like a normal one - havent had them side by side yet tho :!:
also got the flywheel off - i'll take a pic of it when i get home but i dont think its same as sierra - ive never seen one like it before - and the spigot bearing is in the flywheel - not the crank :!: but someone may be able to identify it :? :D
i aslo bought a new clutch off ebay and its just arrived ................. and its wrong :x , incorrectly listed, but i'll try to get the correct one :!:
and the plate - its off too - not exactly a just piece of plate drilled - it has locating bosses and the starter has a locating plate too but if you didnt have the correct flywheel im not sure that would work- but i'll post photos of that too :D
Postby dipstick » Sat Nov 11, 2006 5:20 pm
Luke..... :)
... on the way then..... the flywheel is def a 'SVO' !, a lot different to the car ones or other Transit ones i have seen ....
What starter motor was fitted to yours, mine was marked up as a Granada DOHC Auto....
good luck :)
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Sun Nov 12, 2006 3:13 pm
What diameter is your flywheel. the one i got is too small :( was a long shot thou come off a 2.3 i think :? :?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sun Nov 12, 2006 5:11 pm
Guy88 wrote:What diameter is your flywheel. the one i got is too small :( was a long shot thou come off a 2.3 i think :? :?
the ring gear dia is 298mm o/d and the friction face is 330mm i'll post some pics - i have them at home :D
Postby Luke » Sun Nov 12, 2006 5:21 pm
conversion update - took the pinto out of the van today, started on getting the wiring out of the cossy - apart from that nowt :(
2.9 v6 trasnit flywheel dimensions
Postby dipstick » Sun Nov 12, 2006 8:43 pm
The 2.9 V6 flywheel that came off an SVO Police Transit measures:
330mm dia friction face
298mm across gear side
approx 52mm from edge of friction surface to edge of gears
i hope some of this may be a help?
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Sun Nov 12, 2006 10:12 pm
OK here's a pic :shock:
part numbers all proper 2.9 Transit bits
2.9 transit flywheel - 89 VB 6375 AB DOKLA
ring gear - 11 405 073
2.9 to mt75 adapter plate - cant read it till it's cleaned i'll edit it in
starter motor mounting plate - 89 VB 11K 196-AB
Clutch - AP 10-10½ D5
friction disk - 47809
Edit - cant find a part number on the plate so i guess 89 VB 11K 196-AB off the starter mounting plate is the number for the plate too :?
Edit 2 - the ring gear has 138 teeth
Postby popuptoaster » Mon Nov 13, 2006 8:07 am
flipping eck thats a flywheel and a half!! i guess is that deep to account for the adapter between the engine and box, looks bigger around than a car one as well but its a bit hard to tell from a pic.
popuptoaster
Postby Guy88 » Mon Nov 13, 2006 7:56 pm
Right. The ring gear is bigget than the car one to make it meet the starter ont he adaptor plate.
If you use the car flywheel the starter needs moving :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sun Dec 03, 2006 6:08 pm
well started ripping the engine out of the granny - :x never known a big car with such a difficult access :lol: gave up today - too cold and windy :x
my plan is to fit the engine and box before painting the engine bay - thinking about it its the sensable way any modding/welding etc can be done and not need repainting then i'll pull it all out and paint then refit :D
Postby dipstick » Sun Dec 03, 2006 9:14 pm
Luke,
how have you managed to get the ex manifolds past the adapter plate?
... cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Sun Dec 03, 2006 9:22 pm
I was going to ask that. im doing a little design now :shock:
Luke if you need any help with the loom iv just worked mine out AGAIN cus the labels fell off :x :oops: :oops:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
