Its a Mk5 SWB 2.5Di fitted with a turbo, 100ps injectors and tuned considerably
So its a MT75 box
Now, its done around 70,000 miles, but it lived in a city for most of its life, so the clutch has had a lot of use....
I've adjusted it again, but its definitely in need of replacement now (the extra power has probably finished it off
Now then, I will be fitting a turbo clutch instead of the N/A clutch
and it will be a complete kit (pressure plate, friction plate and release bearing)
However, before I order a clutch kit, I want to ask you all about something in the back of my mind.....
Were there 2 sizes of clutch available?
I seem to remember something about the standard being 245mm, but there was a bigger, heavier duty 267mm clutch
Heavier duty clutch would be useful considering the state of tune
